Aller au contenu principal
How to Install and Remove Tiles
Ce dont vous avez besoin
  1. How to Install and Remove Tiles, Remove the Front Panel: étape 1, image 1 de 3 How to Install and Remove Tiles, Remove the Front Panel: étape 1, image 2 de 3 How to Install and Remove Tiles, Remove the Front Panel: étape 1, image 3 de 3
    • Use your fingers to pull the Front Panel off the magnets securing it to the chassis.
  2. How to Install and Remove Tiles, Remove the Tiles: étape 2, image 1 de 3 How to Install and Remove Tiles, Remove the Tiles: étape 2, image 2 de 3 How to Install and Remove Tiles, Remove the Tiles: étape 2, image 3 de 3
    • Use your fingers to push the bottom of the Tile up and off the front panel and release its clips.
    • Remove the Tile.
  3. How to Install and Remove Tiles: étape 3, image 1 de 3 How to Install and Remove Tiles: étape 3, image 2 de 3 How to Install and Remove Tiles: étape 3, image 3 de 3
    • Repeat this procedure for the remaining tiles.
  4. How to Install and Remove Tiles, Install the Tiles: étape 4, image 1 de 3 How to Install and Remove Tiles, Install the Tiles: étape 4, image 2 de 3 How to Install and Remove Tiles, Install the Tiles: étape 4, image 3 de 3
    • Tiles can be installed in any orientation, even the ones with graphics.
    • Lay a Tile over an open slot on your Front Panel.
    • Use your fingers to press the tile into the slot and engage the clips.
    • You'll hear and feel an audible "click" when the clips engage.
  5. How to Install and Remove Tiles: étape 5, image 1 de 3 How to Install and Remove Tiles: étape 5, image 2 de 3 How to Install and Remove Tiles: étape 5, image 3 de 3
    • Install the remaining Tiles.
  6. How to Install and Remove Tiles: étape 6, image 1 de 3 How to Install and Remove Tiles: étape 6, image 2 de 3 How to Install and Remove Tiles: étape 6, image 3 de 3
    • Lay the bottom of the Front Panel on the small, protruding lip in the silver base to align its tabs.
    • Press the Front Panel flat to the chassis and let it align to the magnets.
If you need help, contact Framework support.
Alex Diaz-Kokaisl
Membre depuis le 01/16/22
213 380 Réputation
1 040 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 14
Total : 180
