Aller au contenu principal
How to JBL L40
Ce dont vous avez besoin
  1. How to JBL L40, How to JBL L40: étape 1, image 1 de 1
    • To remove the speaker from the cabinet, unscrew the 4 screws being careful not to slip and pierce the paper cone.
    • Once the screws are removed gently pull the speaker out of the cabinet.
    • There will be 2 wires attached to the speaker, remove them making sure to mark the polarity of them if they are not marked already.
  2. How to JBL L40: étape 2, image 1 de 1
    • Here is the speaker removed from the cabinet, you can clearly see the degraded state of the foam surround. Luckily this makes it very easy to remove it.
    • These next steps require careful attention to detail. Work slowly and carefully. You do not want to puncture/tear/rip the paper cone or any other components.
    • Remove the black foam ring.
    • Try to do as much of this by hand as you can. You do not want to damage the ring as you will need it for re assembly.
    • Carefully run your knife between the ring and the outer metal edge.
    • Now using your hands and knife when needed remove the black ring from the speaker frame. Prying slowly. Take care not to tear it.
    • Once the ring is removed rub all of the old foam surround off and set aside for reassembly
    • Remove all of the old foam surround from the cone and speaker frame. It was so crumbly on mine that all it took was a bunch of rubbing with my fingers. If you are having trouble use your knife, but again be careful.
  3. How to JBL L40: étape 5, image 1 de 1
    • You can see some of the glue seeped out, it will dry clear so don't worry.
  4. How to JBL L40: étape 6, image 1 de 1
    • Spread glue on the ring you removed earlier
    • place over the foam ring and press on securly
    • allow everything over night to dry completely.
  5. How to JBL L40: étape 7, image 1 de 1
    • Connect the wires to the speaker being mindfull of the polarity.
    • Gently fit the speaker into the housing
    • Line up the screws and progressively tighten them until the speaker is secured
4 autres ont terminé cette réparation.
David Salerno
Membre depuis le 09/14/11
823 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 6,987
