Aller au contenu principal
How to Keurig K75 Platinum Brewing System
Ce dont vous avez besoin
  1. How to Keurig K75 Platinum Brewing System, How to Keurig K75 Platinum Brewing System: étape 1, image 1 de 2 How to Keurig K75 Platinum Brewing System, How to Keurig K75 Platinum Brewing System: étape 1, image 2 de 2
    • Before beginning the repair, turn off and unplug the brewer from any power source.
    • Move the brewer so that the bottom is easily accessible.
    • Unscrew the five 4mm silver diagrammed screws using a #2 Philips Head screwdriver.
  2. How to Keurig K75 Platinum Brewing System: étape 2, image 1 de 2 How to Keurig K75 Platinum Brewing System: étape 2, image 2 de 2
    • Using a spudger, gently pry open the base metal plate from the brewer.
    • Gently place the base of the brewer down.
  3. How to Keurig K75 Platinum Brewing System: étape 3, image 1 de 1
    • Locate the vacuum apparatus within the Keurig B70 Platinum.
    • Using a #00 Phillips screwdriver, unscrew the three 15 mm black screws diagrammed.
  4. How to Keurig K75 Platinum Brewing System: étape 4, image 1 de 1
    • Using a spudger, lift the white piece of the vacuum away from the black membrane.
    • Realign the circular pieces of the membrane so that the circles lie flush inside the black membrane apparatus.
14 autres ont terminé cette réparation.
Kristen Temnyk
Membre depuis le 01/24/13
515 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 20-2, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 20-2, Maness Winter 2013
CPSU-MANESS-W13S20G2
4 membres
6 tutoriels rédigés
22 commentaires
Thank you for this, it saved me from having to purchase a new Keurig. My Keurig was not pushing water out for a cup of coffee. I tried the paperclip in the needle, which didn't work. Thanks again!!!!!
gleasonme - Réponse
I cant get the little screws off of the vacuum. I broke 3 screwdrivers. Could they be glued?
Christina Garrity - Réponse
After you take the white piece of the vaccuum pump off, you will see the black rubber diaphragm just below. DO NOT REMOVE the black rubber diaphragm. It is not necessary to remove this piece, and it will NOT BE POSSIBLE to re-assemble the pump after you remove it. Just clear any obstructions and put the white piece with the tube back on.
I removed the black diaphragm before I realized what it was, and now my Keurig K75 Platinum ($) is heading to the landfill. Hopefully this will prevent somebody else from making that same mistake.
John - Réponse
Dang... didn't expect it to work... but it did!!
kimmpowers2004 - Réponse
This worked for me. When i took off the white piece 2 of the 3 little rubbery, indented pieces were recessed and one was popped out a bit. I pushed them all in and it seemingly fixed the problem. I ran it about three times so far and it is working properly so hopefully it stays working for a while.
rsivisoulivi - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 27
Total : 34,515
