Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Lengthen Dress Pants
Ce dont vous avez besoin
  1. How to Lengthen Dress Pants, How to Lengthen Dress Pants: étape 1, image 1 de 1
    • Start by carefully ripping the seam of the pants with a seam ripper. Make sure not to leave holes in the fabric or it will show in the finished product.
    Demander à FixBot
    Ajouter un commentaire
  2. How to Lengthen Dress Pants: étape 2, image 1 de 1
    • Next, iron the crease left previously by the seam.
    • Some fabrics cannot take high heat. Consult the tag of the garment for ironing instructions. Consider placing layers of fabric between the iron and garment to reduce heat.
    Demander à FixBot
  3. How to Lengthen Dress Pants: étape 3, image 1 de 1
    • Try on the pants. Have a partner pin the pants to the desired length.
    • If you do not have someone to help, measure the inseam of the pants and pin to the desired length.
    Demander à FixBot
  4. How to Lengthen Dress Pants: étape 4, image 1 de 1
    • Measure the width of the pant leg, double that measurement, and add 1.5 inches for seam allowance. Cut the bias tape to match this width.
    Demander à FixBot
  5. How to Lengthen Dress Pants: étape 5, image 1 de 1
    • Sew the bottom of the pant to the edge of the bias tape.
    • Make sure to remove pins while sewing as you move the work closer to the needle to avoid damaging the machine.
    Demander à FixBot
  6. How to Lengthen Dress Pants: étape 6, image 1 de 1
    • Fold the bias tape underneath (about 3/4" -1") and iron flat. Make sure that the bias tape is not visible. Pin the two layers together.
    Demander à FixBot
  7. How to Lengthen Dress Pants: étape 7, image 1 de 1
    • Sew the new seam of the pants.
    • If sewing with a machine, consult the machine's manual on how to do a blind stitch. If sewing by hand, use a tacking stitch. Make sure to only sew the two layers of fabric and not the entire pant-- this will cause the leg of your pants to not have an opening.
    Demander à FixBot
  8. How to Lengthen Dress Pants: étape 8, image 1 de 1
    • Repeat steps 1-7 for the other pant leg and iron flat.
    Demander à FixBot
2 autres ont terminé cette réparation.
CASSANDRA ROBBINS
Membre depuis le 09/30/16
157 Réputation
1 tutoriel rédigé
Équipe
Missouri Western, Team 1-12, Adkins Fall 2016 Membre de l'équipe Missouri Western, Team 1-12, Adkins Fall 2016
MWSU-ADKINS-F16S1G12
2 membres
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 43
Total : 14,152
