Aller au contenu principal
How to Lengthen a Necktie
Ce dont vous avez besoin
  1. How to Lengthen a Necktie, How to Lengthen a Necktie: étape 1, image 1 de 2 How to Lengthen a Necktie, How to Lengthen a Necktie: étape 1, image 2 de 2
    • Measure for the length to add to the tie by measuring from the end of the tie to the belt loop.
    • Add five inches to that length. This is how long your fabric insert should be.
    • In this photo, the tie is 8 inches too short. Add the 8 inches to the 5 inches needed for seams. I need 13 extra inches for the fabric insert.
  2. How to Lengthen a Necktie: étape 2, image 1 de 2 How to Lengthen a Necktie: étape 2, image 2 de 2
    • In this step, measure to find out where to add the extra fabric to the tie, so that the insert will be hidden beneath the collar.
    • Measure from the clavicle to the belt loop.
    • Add two inches.
    • In this photo, the person is 22" from clavicle to belt loop, so I will insert the fabric at 24" from the wide tip of the tie.
  3. How to Lengthen a Necktie: étape 3, image 1 de 1
    • From the widest end of the tie, measure the desired length, in this case, 24 inches.
    • Mark the spot with a fabric marker. This is where you will cut the tie in Step 7.
  4. How to Lengthen a Necktie: étape 4, image 1 de 1
    • Rip the seams along the back of the tie using a seam ripper.
  5. How to Lengthen a Necktie: étape 5, image 1 de 2 How to Lengthen a Necktie: étape 5, image 2 de 2
    • Remove the inner white section of the tie by folding outward and placing on the widest part of tie.
  6. How to Lengthen a Necktie: étape 6, image 1 de 1
    • Unfold the tie.
    • Measure the diagonal width of the tie.
    • You will cut the piece of fabric insert to this width.
  7. How to Lengthen a Necktie: étape 7, image 1 de 1
    • Using a rotary cutter on a cutting board, cut the tie diagonally along the section you marked with the fabric marker in Step 3.
  8. How to Lengthen a Necktie: étape 8, image 1 de 2 How to Lengthen a Necktie: étape 8, image 2 de 2
    • Cut a piece of fabric to match the length and width desired.
    • In this case, I am adding a piece of fabric 13 inches long and 6 inches wide, but the measurements will be different for each person depending on the width of the tie and the length being added.
  9. How to Lengthen a Necktie: étape 9, image 1 de 2 How to Lengthen a Necktie: étape 9, image 2 de 2
    • Pin the extra fabric along the cut portion of the tie so that added fabric forms a "V."
  10. How to Lengthen a Necktie: étape 10, image 1 de 1
    • Sew the insert in place.
  11. How to Lengthen a Necktie: étape 11, image 1 de 1
    • Pin second portion of original tie in place so that the original tie and the added fabric forms a "V".
  12. How to Lengthen a Necktie: étape 12, image 1 de 1
  13. How to Lengthen a Necktie: étape 13, image 1 de 1
    • After sewing both ends in place, the tie should look like this.
    • Unfold the inner tie lay it back inside the tie.
  14. How to Lengthen a Necktie: étape 14, image 1 de 2 How to Lengthen a Necktie: étape 14, image 2 de 2
    • Iron the inserted fabric so that it follows the fold pattern of the original tie.
  15. How to Lengthen a Necktie: étape 15, image 1 de 1
    • Hand sew down the entire length of the back of the tie.
  16. How to Lengthen a Necktie: étape 16, image 1 de 2 How to Lengthen a Necktie: étape 16, image 2 de 2
    • The tie is now the desired length and will reach the belt when worn.
This repair is a great knowledge to have for tall people who wear ties on a regular basis.
Mel Anderson
Membre depuis le 06/13/21
253 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 76
Total : 1,412
