Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Make Your Skinny Jeans Baggier
Ce dont vous avez besoin
    1. How to Make Your Skinny Jeans Baggier, How to Make Your Skinny Jeans Baggier: étape 1, image 1 de 1
      • Flip your jeans inside out.
      • Use pins or chalk to mark where you want to cut the inseams of the jeans you want to modify.
      • You can cut either along the inside or the outside seams of your jeans.
      Demander à FixBot
      Ajouter un commentaire
    2. How to Make Your Skinny Jeans Baggier: étape 2, image 1 de 1
      • Start cutting alongside the inseam you chose.
      • Typically, using a seam ripper is a lot faster, but you can still get the job done with a pair of scissors.
      • This particular step is tedious, especially without the proper tools. Do not try using something like a knife or box cutter. You may harm yourself.
      Demander à FixBot
    3. How to Make Your Skinny Jeans Baggier: étape 3, image 1 de 2 How to Make Your Skinny Jeans Baggier: étape 3, image 2 de 2
      • Use a measuring tape to measure from the bottom of the pant leg to where you want to cut.
      • To measure how wide you want the jeans, grab a pair that you already have that fit you how you like them. Align them with the jeans you are modifying.
      • Measure the bottom width, double it, and then add two or three inches more.
      • Make sure to cut a little wider so you have room for error.
      Demander à FixBot
    4. How to Make Your Skinny Jeans Baggier: étape 4, image 1 de 1
      • Use fabric chalk to mark a triangle the length and size of the area you are adding to your jeans
      • Use sewing scissors to cut along the triangle of your donor jeans or denim fabric.
      • Pin the corners of the denim piece onto the other pant leg to make sure that both sides are the same size.
      Demander à FixBot
    5. How to Make Your Skinny Jeans Baggier: étape 5, image 1 de 1
      • Pin the pieces you just cut onto the inseams with pins.
      • Sew the edges together.
      • This step will take a long time to do by hand, but it is possible. I still recommend using a sewing machine if you can, so the process goes a lot quicker. The stitches will also be more secure.
      • Be careful when sewing. While doing it by hand, you might poke yourself. When using a machine, keep your fingers away from the needle.
      • Try on one pant leg. If you don't like it, it's not too late to undo the stitches and either make it wider or slimmer. Otherwise, you're done!
      Demander à FixBot
Enjoy your roomier jeans!
Lizzy Escobar
Membre depuis le 04/15/25
121 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team L-14, Harris Spring 2025 Membre de l'équipe CSU Los Angeles, Team L-14, Harris Spring 2025
CSULA-HARRIS-S25SLG14
1 membre
4 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 16
30 derniers jours : 50
Total : 597
