Aller au contenu principal
How to Make a Jeans Patch Less Noticeable
Ce dont vous avez besoin
  1. How to Make a Jeans Patch Less Noticeable, How to Make a Jeans Patch Less Noticeable: étape 1, image 1 de 2 How to Make a Jeans Patch Less Noticeable, How to Make a Jeans Patch Less Noticeable: étape 1, image 2 de 2
    • Place the jeans on an even surface.
    • Flip your jeans inside out.
  2. How to Make a Jeans Patch Less Noticeable: étape 2, image 1 de 3 How to Make a Jeans Patch Less Noticeable: étape 2, image 2 de 3 How to Make a Jeans Patch Less Noticeable: étape 2, image 3 de 3
    • Trim any loose thread around the hole.
    • After cleaning the area, use the iron to warm the area before placing the patch.
  3. How to Make a Jeans Patch Less Noticeable: étape 3, image 1 de 2 How to Make a Jeans Patch Less Noticeable: étape 3, image 2 de 2
    • Grab the patch and iron it on until it is secured to the jeans.
  4. How to Make a Jeans Patch Less Noticeable: étape 4, image 1 de 3 How to Make a Jeans Patch Less Noticeable: étape 4, image 2 de 3 How to Make a Jeans Patch Less Noticeable: étape 4, image 3 de 3
    • Start preparing your thread and needle and knot the end of the thread.
    • Push the needle from the back to the front.
    • Create an outline of the part where the patch is visible, until a circle is formed.
  5. How to Make a Jeans Patch Less Noticeable: étape 5, image 1 de 3 How to Make a Jeans Patch Less Noticeable: étape 5, image 2 de 3 How to Make a Jeans Patch Less Noticeable: étape 5, image 3 de 3
    • Push the needle from the back to the front, filling in the hole.
    • Repeat this process until the hole is covered and the patch is not showing.
    • Tie off the thread in a knot on the inside of the jeans.
  6. How to Make a Jeans Patch Less Noticeable: étape 6, image 1 de 2 How to Make a Jeans Patch Less Noticeable: étape 6, image 2 de 2
    • Grabbing a new color thread, tie off a knot like mentioned in step 4.
    • Starting inside, create your desired design (we decided a moon and stars).
    • Push the needle back to front creating little clumps within the hole.
    • When you have finished the design tie it off on the inside of the jeans.
  7. How to Make a Jeans Patch Less Noticeable: étape 7, image 1 de 1
    • Cut a new piece of thread and place it on the inside.
    • Push the needle back to front of the jeans and push it back inside a few centimeters down.
    • Repeat this threading technique a few times, creating a star.
    • Tie off the thread on the inside of the jean.
    • Cut any excess thread from the inside of the jean.
    • Jeans are now ready to be worn.
Ligne d'arrivée
Alejandra Gonzalez Manzo
Membre depuis le 04/22/24
145 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 2-5, Whithaus Spring 2024 Membre de l'équipe UC Davis, Team 2-5, Whithaus Spring 2024
UCD-WHITHAUS-S24S2G5
3 membres
3 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 22
30 derniers jours : 53
Total : 529
