Introduction
This works on cacti that have a main body with limbs (instead of succulents). Remember to have protective gloves and that it may take some time for the cactus to heal back to its original state. Our guide will allow the option to mend the cacti that you have been growing for a long time, instead of feeling like your cactus is a lost cause.
Ce dont vous avez besoin
First, check the status of your cactus by assessing its dryness. If it feels dried out, an extra step will have to be taken.
Use the string to tie cactus together. A simple string like embroidery floss works fine.
Wind the string around your cactus carefully. Make sure to cross the string over the other, creating a perpendicular line.
Repeat this step multiple times until you have wound the string above and below the wound.
The string should be tight enough to create support for the cactus.
Unlike the previous steps, let the broken cactus limb dry out in a shady area in room temperature for about 2 days (or until the end calluses over).
Having a calloused piece prevents the cactus from drying out completely and stops plant diseases from entering and infecting the wound.
Once the piece is properly calloused, take the cactus and press it gently into the soil. The piece should be resting slightly in the soil and does not have to be buried deep.
However, if the broken limb is large, bury the cut end of the limb until it can fully support itself on its own in the soil.
With the appropriate care of your cactus, it should be fully healed and continue to grow!
8 autres ont terminé cette réparation.
2 commentaires
Thank you , help me a lot! I accidentally cut off my cactus because i though it was rotten after the plant under it rotting from too much water. Here's cactus for you 🎉🌵🌵🌵🎊
I am looking for a way to obstruct the holes a woodpecker created in a Saguaro Cactus. This plant is 100+ years old and 25+ feet all with three fully developed arms. The solution must be able to withstand 120 degree weather in summer. Any Suggestions?
