Aller au contenu principal
How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator)
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
Ce dont vous avez besoin
  1. How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator), How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): étape 1, image 1 de 1
    • Remove the covering cap. (pg. 23)
  2. How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): étape 2, image 1 de 1
    • Place the unit upside down on a non-slip surface and remove the six screws. (pg. 23)
  3. How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): étape 3, image 1 de 1
    • Remove the lower part of the housing with a swiveling motion away to the side. Note the SOMNOcomfort series uses a shorter circuit board than the balance series ventilator. (pg. 23)
  4. How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): étape 4, image 1 de 3 How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): étape 4, image 2 de 3 How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): étape 4, image 3 de 3
    • Remove the connector (X1) from the circuit board.
    • Pull the connecting cable (64) from its mount.
    • Now set aside the lower part of the housing. (pg. 23)
  5. How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): étape 5, image 1 de 2 How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): étape 5, image 2 de 2
    • Next, how to close the compartment and reverse the process.
    • Hold the lower part of the housing to the upper part at an angle
    • Attach the connector (X1) to the main circuit board. When doing so the connector’s nub has to point towards the lock. (pg. 24)
  6. How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): étape 6, image 1 de 2 How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): étape 6, image 2 de 2
    • Properly align the main circuit board inside the unit.
    • Attach the connecting cable (64) to its mount (pg. 24)
  7. How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): étape 7, image 1 de 1
    • Place the lower part of the housing on the upper part (47). Please make sure the main circuit board (44) is aligned properly, and that the connecting cable (64) is not being squeezed anywhere. (pg. 24)
  8. How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): étape 8, image 1 de 1
    • Now reattach the upper part of the housing by tightening the six screws. (pg. 24)
  9. How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): étape 9, image 1 de 1
    • Insert the covering cap. (pg. 24)
Now, you can properly assemble and reassemble the SOMNOcomfort and SOMNObalance ventilators in order to perform and necessary repairs.
Diya Jamwal
Membre depuis le 11/07/18
553 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S1-G3, Zimmerman Spring 2020 Membre de l'équipe Cal Poly, Team S1-G3, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G3
5 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 196
