Aller au contenu principal
How to Patch a Hole in a Plastic Trash Can
Ce dont vous avez besoin
  1. How to Patch a Hole in a Plastic Trash Can, How to Patch a Hole in a Plastic Trash Can: étape 1, image 1 de 3 How to Patch a Hole in a Plastic Trash Can, How to Patch a Hole in a Plastic Trash Can: étape 1, image 2 de 3 How to Patch a Hole in a Plastic Trash Can, How to Patch a Hole in a Plastic Trash Can: étape 1, image 3 de 3
    • Remove any obstructions such as labels.
    • Wipe down your trash can to ensure there is no debris on the surface.
  2. How to Patch a Hole in a Plastic Trash Can: étape 2, image 1 de 2 How to Patch a Hole in a Plastic Trash Can: étape 2, image 2 de 2
    • Cut a piece of duct tape equal to the length of the cracks and/or holes on your trash can.
    • You may need more than one piece of tape if the damage is significant.
    • Place the duct tape on the inside where the damage is present.
  3. How to Patch a Hole in a Plastic Trash Can: étape 3, image 1 de 3 How to Patch a Hole in a Plastic Trash Can: étape 3, image 2 de 3 How to Patch a Hole in a Plastic Trash Can: étape 3, image 3 de 3
    • This step deals with material that can be harmful if inhaled and/or it makes contact with your skin. It is with utmost importance that you wear proper PPE (personal protective equipment). Disposable gloves and an N95 face mask are highly recommended.
    • Follow the instructions on the back of the Bondo Short Strand Fiberglass Filler label for proper measurements of the filler.
    • Add in a sufficient amount of Bondo Cream Hardener according to the Bondo Fiberglass Filler label.
    • Mix together until this mixture becomes a single color.
  4. How to Patch a Hole in a Plastic Trash Can: étape 4, image 1 de 3 How to Patch a Hole in a Plastic Trash Can: étape 4, image 2 de 3 How to Patch a Hole in a Plastic Trash Can: étape 4, image 3 de 3
    • Use a 1/2" plastic putty knife to apply the mixture to the outside of your trash can.
    • If the surface of your trash can is extremely smooth, sand the area around the damage before applying the mixture to allow it to adhere better to the surface.
    • This mixture will begin to harden within 3 to 4 minutes, so work as fast as you can to get an even layer on the surface.
    • Allow the mixture to cure on your trash can for at least 30 minutes.
  5. How to Patch a Hole in a Plastic Trash Can: étape 5, image 1 de 2 How to Patch a Hole in a Plastic Trash Can: étape 5, image 2 de 2
    • Once the mixture has fully cured, use a strip of 80 grit sandpaper to sand the hardened mixture.
    • In addition to wearing a mask, this step should be done outdoors or in a properly ventilated area to reduce the risk of inhaling the sanded debris.
  6. How to Patch a Hole in a Plastic Trash Can: étape 6, image 1 de 2 How to Patch a Hole in a Plastic Trash Can: étape 6, image 2 de 2
    • When you're satisfied with your sanding job, remove the duct tape from inside the trash can.
Now you're done!
Suzy Lee
Membre depuis le 02/21/24
183 Réputation
1 tutoriel rédigé
Équipe
CSU Sacramento, Team G-9, Laflen Spring 2024 Membre de l'équipe CSU Sacramento, Team G-9, Laflen Spring 2024
CSUSAC-LAFLEN-S24SGG9
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 11
30 derniers jours : 36
Total : 102
