Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Patch a Structured Garment
Ce dont vous avez besoin
  1. How to Patch a Structured Garment, How to Patch a Structured Garment: étape 1, image 1 de 3 How to Patch a Structured Garment, How to Patch a Structured Garment: étape 1, image 2 de 3 How to Patch a Structured Garment, How to Patch a Structured Garment: étape 1, image 3 de 3
    • Measure the area to be patched using a ruler with a sliding bead or sewing measurement tape.
    • If using a tape, use pins to keep the tape straight when measuring the area to be patched.
    • Round up the measurements to ensure the patch is slightly larger than the area that needs to be patched.
    • For example, most of my measurements were 1.75 inches, so I wrote down 2 inches for the length, width, and height.
    Demander à FixBot
  2. How to Patch a Structured Garment: étape 2, image 1 de 3 How to Patch a Structured Garment: étape 2, image 2 de 3 How to Patch a Structured Garment: étape 2, image 3 de 3
    • Trace the recorded measurements for your patch onto the patch fabric using a fabric pencil/marker.
    • A pencil is better for white fabric, and a marker is better for dark or thick fabric.
    • I used satin fabric for my patch cloth because the outer part of the corset is made of satin. Color matching is only important if the garment being patched is being worn outside clothing. My corset is an undergarment, so while I used white satin I didn't use an exact color-match.
    Demander à FixBot
  3. How to Patch a Structured Garment: étape 3, image 1 de 3 How to Patch a Structured Garment: étape 3, image 2 de 3 How to Patch a Structured Garment: étape 3, image 3 de 3
    • Cut out the patch using the recorded measurements.
    • I cut out two equal-sized pieces of cloth in case I needed to do a double layer, but it wasn't necessary. Double layering is needed if the fabric used is too thin, or if it doesn't cover the hole and worn fabric well enough in the original layer.
    • Optional: To double layer a patch, repeat the steps to sew on the original patch. Put the second patch exactly on top of the first.
    Demander à FixBot
  4. How to Patch a Structured Garment: étape 4, image 1 de 1
    • Trim off the raw fabric edges on the patch cloth before sewing.
    • The fuzz on the very edge of a fabric roll gets in the way of sewing, so you still need cut edges for all for sides of the patch fabric.
    Demander à FixBot
  5. How to Patch a Structured Garment: étape 5, image 1 de 3 How to Patch a Structured Garment: étape 5, image 2 de 3 How to Patch a Structured Garment: étape 5, image 3 de 3
    • Wet or wax the end of your thread to make it easier to pull it through the eye of the needle. Do this even if your thread isn't frayed.
    • Waxing thread makes it sturdier and less prone to snapping while sewing. Buy sewing beeswax online or at a specialty sewing store.
    • Draw out a long length of thread (I usually do between a foot and a yard depending on how much I need). Wax the length of the thread if using wax.
    • Take the two ends of the thread (with the needle in the middle) and knot the ends together. Your needle should be trapped in a tied loop of thread. This prevents the thread from getting lost while sewing.
    Demander à FixBot
  6. How to Patch a Structured Garment: étape 6, image 1 de 3 How to Patch a Structured Garment: étape 6, image 2 de 3 How to Patch a Structured Garment: étape 6, image 3 de 3
    • Pick one corner of the area to be repaired. Place the patch cloth on the area (pin it if necessary) and bring the needle up through the garment fabric and through the bottom of the patch. Pull the thread all the way through until the knot at the end of the line catches and holds fast. Continue with the next stitch.
    • Rethread the needle if you run out of thread/the thread breaks. Tie a new knot at the end. Start resewing from the bottom just as before, slightly behind your most recent stitch to create overlap. Then continue sewing.
    • Fold over raw edges to sew them under the patch before beginning. Use a whip stitch, an overcast stitch, or a catch stitch to keep the patch secure and ensure lasting stitches.
    • Hand Sewing Repairs article from Design Life Hacks has some excellent examples of types of stitches.
    Demander à FixBot
  7. How to Patch a Structured Garment: étape 7, image 1 de 3 How to Patch a Structured Garment: étape 7, image 2 de 3 How to Patch a Structured Garment: étape 7, image 3 de 3
    • When patching on a garment's edge, you will have two sides to sew up. Complete the first side.
    • Fold the patch over the edge until it covers the back of the torn area. If the patch fabric is too long/large on this side, trim it with the sewing scissors.
    • Fold the trimmed edges underneath just like the other side and continue sewing. Sew around corners using the same line and a crosshatch stitch at corners.
    • Use a thimble while sewing around difficult obstacles like corset boning to avoid pricking your finger. An easy DIY if you do not have your own thimble is to cover your thumb in two overlapping band-aids to form a protective covering. A band-aid covering is better than a glove because gloves limit dexterity.
    Demander à FixBot
  8. How to Patch a Structured Garment: étape 8, image 1 de 3 How to Patch a Structured Garment: étape 8, image 2 de 3 How to Patch a Structured Garment: étape 8, image 3 de 3
    • To complete a line of stitches, create a loose stitch. Loop the needle several times around the inside of the looped stitch and then pull the thread all the way through. Pull this tight to make a knot. Trim all loose threads with the sewing scissors after you are done to remove visible loose threads.
    • Optional: Rip any stitches that need to be redone with a seam ripper. Pull the old line out and start that section over.
    • Finish trimming and repairs. Smooth over the edges and examine for any other flaws. Now the patching is complete!
    Demander à FixBot
Once the repairs are complete, try on your structured garment and wear it doing the sorts of movements you would normally do in the garment. If any threads snap, you will need to resew the broken section more securely. If not, enjoy the extended life of your repaired garment!
SarahManders
Membre depuis le 09/09/25
157 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 31
Total : 144
