Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
If your Apple Watch’s touchscreen is broken or doesn’t respond to touch, you can’t power it down using the slide-to-power-off controls. Instead, follow this guide to switch off your Apple Watch using the side button and digital crown. After turning off your watch, you can proceed with repairs.
  1. If your Apple Watch is charging, unplug it from the charger, or this procedure won't work. Press and hold both the side button and digital crown simultaneously.
    • If your Apple Watch is charging, unplug it from the charger, or this procedure won't work.
    • Press and hold both the side button and digital crown simultaneously.
    • Continue holding while the Apple Watch reboots.
  2. When you see the Apple logo, release the digital crown. Continue holding the side button. When the Apple logo disappears, release the side button. When the Apple logo disappears, release the side button.
    • When you see the Apple logo, release the digital crown. Continue holding the side button.
    • When the Apple logo disappears, release the side button.
  3. The Apple Watch is now powered off.
    • The Apple Watch is now powered off.
That’s all! With your Apple Watch safely powered down, you can proceed with repairs.
31 autre(s) ont terminé cette réparation.
Jeff Suovanen
Membre depuis le 06/08/2013
331 709 Réputation
257 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
135 membres
13 958 tutoriels rédigés
Hi Jeff, is this supposed to work with series 3 watches. All I see is the time and a red lightning bolt which then disappears and then reappears
Ed Rutmayer - Réponse
bonjour
comment s
Nacache - Réponse
comment savoir si la batterie est defectueuse mon apple watch serie nike +affiche la pomme et celle-ci diparait serait la batterie ou la mise a jour je ne peux la synchroniser avec mon iphone vu qu’elle ne demare plus merci a vous de me rensseigner
Nacache - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 20
7 derniers jours : 238
30 derniers jours : 957
Total : 15,521
