Aller au contenu principal
How to Propagate a Plant in Water
Ce dont vous avez besoin
  1. How to Propagate a Plant in Water, How to Propagate a Plant in Water: étape 1, image 1 de 2 How to Propagate a Plant in Water, How to Propagate a Plant in Water: étape 1, image 2 de 2
    • Using scissors or shears cut the plant below a node.
    • Node: a point where a leaf or branch emerges.
  2. How to Propagate a Plant in Water: étape 2, image 1 de 2 How to Propagate a Plant in Water: étape 2, image 2 de 2
    • Remove the bottom leaves and cut the plant diagonally.
    • Cutting the plant in a diagonal will increase surface area and allow for better water consumption.
  3. How to Propagate a Plant in Water: étape 3, image 1 de 2 How to Propagate a Plant in Water: étape 3, image 2 de 2
    • Optional: Coat the cutting in rooting powder.
    • Rooting powder will accelerate the rooting process and yield a higher success rate.
  4. How to Propagate a Plant in Water: étape 4, image 1 de 1
    • Fill a glass cup with water.
  5. How to Propagate a Plant in Water: étape 5, image 1 de 1
    • Place the cutting in the cup.
    • The cup should be in a well-ventilated area with bright indirect light.
    • Change the water every week to prevent bacterial growth.
  6. How to Propagate a Plant in Water: étape 6, image 1 de 2 How to Propagate a Plant in Water: étape 6, image 2 de 2
    • Once the roots are 1-2 inches long, transfer to medium (soil, lecca, etc.).
    • Water regularly to reduce shock.
You did it! Congratulations on successfully propagating your plant in water!
3 autres ont terminé cette réparation.
Daniela Perez
Membre depuis le 02/21/24
187 Réputation
1 tutoriel rédigé
Équipe
CSU Sacramento, Team 1-14, Laflen Spring 2024 Membre de l'équipe CSU Sacramento, Team 1-14, Laflen Spring 2024
CSUSAC-LAFLEN-S24S1G14
2 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 14
Total : 81
