Aller au contenu principal
How to Re-caulk a Bathroom
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. How to Re-caulk a Bathroom, How to Re-caulk a Bathroom: étape 1, image 1 de 1
    • Use a knife to uproot the old caulk that is sealed to the wall.
  2. How to Re-caulk a Bathroom: étape 2, image 1 de 1
    • Peel off until all of the caulk is removed.
  3. How to Re-caulk a Bathroom: étape 3, image 1 de 1
    • Remove all of the residual caulk that lies under the main slabs that were just pulled off.
    • Do this by angling the tip of the blade into the pivot and scraping up the caulk that lies there.
  4. How to Re-caulk a Bathroom: étape 4, image 1 de 3 How to Re-caulk a Bathroom: étape 4, image 2 de 3 How to Re-caulk a Bathroom: étape 4, image 3 de 3
    • Before applying the new caulk, clean the area with hydrogen peroxide or rubbing alcohol.
    • Let the area dry for about 10 minutes before applying the new caulk. This will allow the new caulk to seal properly.
  5. How to Re-caulk a Bathroom: étape 5, image 1 de 2 How to Re-caulk a Bathroom: étape 5, image 2 de 2
    • Place the tip of the new bottle of caulk into the hole by the trigger.
    • Squeeze the trigger to cut.
  6. How to Re-caulk a Bathroom: étape 6, image 1 de 2 How to Re-caulk a Bathroom: étape 6, image 2 de 2
    • Use something sharp to break the inner seal of the caulk.
    • The use of the pin on the caulking gun (as shown in the 2nd picture) is an alternative to using a blade.
  7. How to Re-caulk a Bathroom: étape 7, image 1 de 2 How to Re-caulk a Bathroom: étape 7, image 2 de 2
    • Push the silver button and pull the spring back to fully open the chamber of the caulking gun.
    • Place the new bottle of caulk into the open chamber.
  8. How to Re-caulk a Bathroom: étape 8, image 1 de 2 How to Re-caulk a Bathroom: étape 8, image 2 de 2
    • To apply the new caulk, press the trigger and drag the gun across the area being re-caulked.
    • When caulking the area, try to use the appropriate amount of caulk. More is better than less.
  9. How to Re-caulk a Bathroom: étape 9, image 1 de 3 How to Re-caulk a Bathroom: étape 9, image 2 de 3 How to Re-caulk a Bathroom: étape 9, image 3 de 3
    • After applying the new caulk, dab a finger in water and smooth it out.
    • The more times you smooth it out, the more caulk you take off. This is why using more is better than using less.
    • It takes 24 hours for new caulking to dry. DO NOT get the surface wet during this time. It will ruin your work.
By using these tools and referring to this guide, you can re-caulk any part of your bathroom with relative ease.
5 autres ont terminé cette réparation.
Nicholas Khorshidi
Membre depuis le 09/29/15
353 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 10-2, Green Fall 2015 Membre de l'équipe Cal Poly, Team 10-2, Green Fall 2015
CPSU-GREEN-F15S10G2
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 15
30 derniers jours : 17
Total : 554
