Aller au contenu principal
How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner
Ce dont vous avez besoin
  1. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner, How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 1, image 1 de 2 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner, How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 1, image 2 de 2
    • The leather door lining is loose.
  2. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner, Remove plastic trim: étape 2, image 1 de 3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner, Remove plastic trim: étape 2, image 2 de 3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner, Remove plastic trim: étape 2, image 3 de 3
    • Using a plastic pry tool, carefully pry off the mock wood trim.
    • The mock wood trim tends to crack easily.
  3. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 3, image 1 de 3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 3, image 2 de 3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 3, image 3 de 3
    • If any of the plastic clips come loose with the trim, remove them and press them back into the door panel.
  4. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 4, image 1 de 2 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 4, image 2 de 2
    • Using a T20 Torx, remove the three screws located behind the previously removed trim.
  5. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 5, image 1 de 3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 5, image 2 de 3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 5, image 3 de 3
    • Using your plastic pry tool, pry the door panel loose, beginning along the bottom edge and moving up each side.
    • The door panel will still be attached at the top.
  6. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 6, image 1 de 1
    • Pull the door panel straight out along the top edge.
    • There is a series of metal clips that will pop lose.
    • When re-installing the door panel, it is important to line these clips back up with their respective holes on the door panel.
  7. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 7, image 1 de 2 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 7, image 2 de 2
    • Unclip the internal door handle mechanism inside the door handle by rotating clockwise.
  8. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 8, image 1 de 1
    • Unplug the speaker wire by pulling it straight out.
  9. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 9, image 1 de 3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 9, image 2 de 3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 9, image 3 de 3
    • Unplug the control panel wire by rotating the lever that is built into the plug.
    • Rotate the lever from the wire side down towards the door panel.
  10. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 10, image 1 de 3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 10, image 2 de 3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 10, image 3 de 3
    • Pop the light out of the bottom of the door panel and then unplug it.
  11. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 11, image 1 de 2 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 11, image 2 de 2
    • Now that the door panel is free from the car, move it to a flat workspace.
    • Apply a line of glue along the top edge and under the middle of the leather liner.
    • Have your clamps and wood spacers ready before applying glue.
  12. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 12, image 1 de 2 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 12, image 2 de 2
    • Push the liner into place in between the door panel sections.
  13. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 13, image 1 de 3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 13, image 2 de 3 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: étape 13, image 3 de 3
    • Using several clamps and pieces of wood (to distribute pressure), clamp the liner down to the door panel.
    • You may need to add larger pieces of wood on the inside of the door panel as spacers.
Allow the glue to dry following the instructions on the tube. Reassemble the door following these instructions in reverse order.
3 autres ont terminé cette réparation.
Sam A McDaniel
Membre depuis le 09/16/20
298 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 15
30 derniers jours : 104
Total : 5,038
