Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster
Ce dont vous avez besoin
    1. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster, How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 1, image 1 de 1
      • Remove all five 5mm Phillips #1 screws from the bottom of the toaster.
      Demander à FixBot
      Ajouter un commentaire
    2. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 2, image 1 de 1
      • Lift the top of the toaster from the bottom section of the toaster.
      • Do this carefully so that you don't damage the switch board.
      Demander à FixBot
    3. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 3, image 1 de 1
      • Look into the toaster and locate the two divots that the support bracket has detached from.
      Demander à FixBot
    4. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 4, image 1 de 2 How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 4, image 2 de 2
      • Locate the detached support bracket.
      • From the back of the toaster (the side opposite the side of the toasting lever), you will see the broken support bracket sticking out.
      Demander à FixBot
    5. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 5, image 1 de 3 How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 5, image 2 de 3 How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 5, image 3 de 3
      • Use the portion of the bracket that is sticking out of the back of the toaster to move the support bracket.
      • Align the support bracket with the two divots on the moving bracket assembly.
      • In this particular model, the shell of the toaster cannot be completely removed. It might be helpful to have a helper hold up the shell of the toaster so that it is not in your way.
      Demander à FixBot
    6. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 6, image 1 de 1
      • Using moderate force, push the teeth of the support bracket into the divots on the moving bracket assembly.
      • If the teeth on the support bracket are damaged, further repair might be necessary in order for them to fit into the divots.
      Demander à FixBot
    7. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 7, image 1 de 2 How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 7, image 2 de 2
      • Carefully lower the shell of the toaster back down to its base.
      • Lift and lower the toasting lever a few times to ensure that the support bracket is firmly in place.
      Demander à FixBot
    8. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: étape 8, image 1 de 1
      • Screw on the bottom of the toaster using all five 5mm Phillips #1 screws.
      Demander à FixBot
Follow these steps and your toaster will be as good as new!
Tori Mobley
Membre depuis le 02/20/18
157 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 52
Total : 3,072
