Aller au contenu principal
How to Rehydrate a Dried Eyeliner Pen
Ce dont vous avez besoin
  1. How to Rehydrate a Dried Eyeliner Pen, How to Rehydrate a Dried Eyeliner Pen: étape 1, image 1 de 1
    • Before you start, test out your dried eyeliner pen so you can compare the results at the end!
  2. How to Rehydrate a Dried Eyeliner Pen: étape 2, image 1 de 2 How to Rehydrate a Dried Eyeliner Pen: étape 2, image 2 de 2
    Outil utilisé dans cette étape :
    • Remove the cap from your eyeliner pen.
    • Take a small pair of pliers and gently remove the felt rod from inside the liner.
    • Some liners may require you to unscrew the end of the liner to remove the felt rod.
    • If you do not have pliers, tweezers can also be used for this fix.
  3. How to Rehydrate a Dried Eyeliner Pen: étape 3, image 1 de 3 How to Rehydrate a Dried Eyeliner Pen: étape 3, image 2 de 3 How to Rehydrate a Dried Eyeliner Pen: étape 3, image 3 de 3
    • Once the felt rod has been removed, gently place the rod in a bowl of warm water for no more than 30 seconds.
    • If you notice the colour of the water starts to change, immediately remove the felt rod from the water.
  4. How to Rehydrate a Dried Eyeliner Pen: étape 4, image 1 de 3 How to Rehydrate a Dried Eyeliner Pen: étape 4, image 2 de 3 How to Rehydrate a Dried Eyeliner Pen: étape 4, image 3 de 3
    • Take the felt rod out of the water and immediately place it on a paper towel.
    • Gently pat the felt rod dry using a paper towel.
  5. How to Rehydrate a Dried Eyeliner Pen: étape 5, image 1 de 2 How to Rehydrate a Dried Eyeliner Pen: étape 5, image 2 de 2
    • Lastly, use a plier to fit the felt rod back into the liner pen.
  6. How to Rehydrate a Dried Eyeliner Pen: étape 6, image 1 de 1
    • Now test out your new eyeliner pen to see the difference!
    • The red arrow shows the before and the blue arrow shows the after.
Ligne d'arrivée
Nuha Naushad
Membre depuis le 09/11/23
133 Réputation
1 tutoriel rédigé
Équipe
York University, Team 2-16, O'Regan Fall 2023 Membre de l'équipe York University, Team 2-16, O'Regan Fall 2023
YORK-O'REGAN-F23S2G16
1 membre
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 204
