Aller au contenu principal
How to Remove Rust on Car Body
Ce dont vous avez besoin
  1. How to Remove Rust on Car Body, How to Remove Rust on Car Body: étape 1, image 1 de 2 How to Remove Rust on Car Body, How to Remove Rust on Car Body: étape 1, image 2 de 2
    • Spray down the rust with a spray bottle mixed with water and dish soap.
    • Wipe the mixture with a microfiber cloth.
  2. How to Remove Rust on Car Body: étape 2, image 1 de 3 How to Remove Rust on Car Body: étape 2, image 2 de 3 How to Remove Rust on Car Body: étape 2, image 3 de 3
    • Pour a small amount of rubbing alcohol onto a microfiber cloth.
    • Clean the rusted area with the cloth to remove any contaminants.
  3. How to Remove Rust on Car Body: étape 3, image 1 de 3 How to Remove Rust on Car Body: étape 3, image 2 de 3 How to Remove Rust on Car Body: étape 3, image 3 de 3
    • Rub the rusted area with 80-grit sandpaper until you start seeing the bare metal.
  4. How to Remove Rust on Car Body: étape 4, image 1 de 2 How to Remove Rust on Car Body: étape 4, image 2 de 2
    • Rub the rusted area with 220-grit sandpaper until all of the rust is removed.
    • Dampen a cloth with soapy water and wipe down the sanded area.
  5. How to Remove Rust on Car Body: étape 5, image 1 de 2 How to Remove Rust on Car Body: étape 5, image 2 de 2
    • This step is to prepare your spot for spray painting.
    • Add some paper around the areas you do not want paint on. Make sure you go a little past where you are going to spray paint to blend the paint into the surrounding area.
  6. How to Remove Rust on Car Body: étape 6, image 1 de 3 How to Remove Rust on Car Body: étape 6, image 2 de 3 How to Remove Rust on Car Body: étape 6, image 3 de 3
    • Spray three even coats of primer, waiting at least five minutes between each coat.
    • Let the third coat sit for 15 minutes.
  7. How to Remove Rust on Car Body: étape 7, image 1 de 3 How to Remove Rust on Car Body: étape 7, image 2 de 3 How to Remove Rust on Car Body: étape 7, image 3 de 3
    • Spray three even coats of paint on top of the primer, waiting five minutes between each coat.
    • You can either use a color similar to your car or you can get the actual color of you car by looking for the car's color code.
    • After the final coat, wait 24 hours before removing the surrounding paper.
Ligne d'arrivée
Robert Gutierrez
Membre depuis le 08/25/22
163 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 10-20, Briggs Fall 2022 Membre de l'équipe CSU Los Angeles, Team 10-20, Briggs Fall 2022
CSULA-BRIGGS-F22S10G20
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 41
30 derniers jours : 112
Total : 1,863
