Introduction
This guide will show you how to extract a screw that has broken while being embedded inside its hole, along with showing you how to replace it with a new one. This process works for screws inside walls, pieces of lumber, or metal. The guide requires a couple of power tools, so you should always use the necessary precautions when using them to avoid any injuries.
Ce dont vous avez besoin
Use an angle grinder to grind the tip of the broken screw until its surface is smooth and even.
3 autres ont terminé cette réparation.
