Aller au contenu principal
How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation)
Ce dont vous avez besoin
  1. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation), How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): étape 1, image 1 de 2 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation), How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): étape 1, image 2 de 2
    • On the top of the printer, turn the injector counter-clockwise and pull the tab.
  2. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): étape 2, image 1 de 3 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): étape 2, image 2 de 3 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): étape 2, image 3 de 3
    • Insert your fingers in the center of the filament cartridge and slowly pull it away from the printer.
  3. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): étape 3, image 1 de 1
    • Place the cartridge face up and pry off the lid of the cartridge.
  4. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): étape 4, image 1 de 2 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): étape 4, image 2 de 2
    • Gently flip the cartridge on its front and remove the two 2mm Hex screws using a Hex key.
  5. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): étape 5, image 1 de 1
    • Flip the cartridge face up and remove the gearbox and extractor tube.
  6. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): étape 6, image 1 de 3 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): étape 6, image 2 de 3 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): étape 6, image 3 de 3
    • Place your thumb on the front of the injector head and your middle finger on the needle.
    • Firmly pull the needle towards your thumb until the injector head cases cracks and pulls apart the case.
  7. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): étape 7, image 1 de 2 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): étape 7, image 2 de 2
    • Heat the needle using a lighter, making sure that the flame does not touch the needle.
    • Using needle-nose pliers, pull the needle from the tube.
    • Do not touch the needle as it may still be hot.
  8. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): étape 8, image 1 de 1
    • Insert a paper clip and turn until the clog is removed.
Hector Vazquez
Membre depuis le 10/23/20
157 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team S12-G11, Harris Fall 2020 Membre de l'équipe CSU Los Angeles, Team S12-G11, Harris Fall 2020
CSULA-HARRIS-F20S12G11
1 membre
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 17
Total : 517
