Aller au contenu principal
How to Remove scratches from a CD
Ce dont vous avez besoin
  1. How to Remove scratches from a CD, How to Remove scratches from a CD: étape 1, image 1 de 1
    • Identify any scratches.
    • Some scratches may be too deep to be removed. In this case, this method may not work.
  2. How to Remove scratches from a CD: étape 2, image 1 de 2 How to Remove scratches from a CD: étape 2, image 2 de 2
    • Take the CD to the sink.
    • Wash with lukewarm water to remove any dust or dirt.
  3. How to Remove scratches from a CD: étape 3, image 1 de 1
    • Let the CD air dry, or dry with towel.
    • Use a non-linen towel or your CD will need to be washed again.
  4. How to Remove scratches from a CD: étape 4, image 1 de 3 How to Remove scratches from a CD: étape 4, image 2 de 3 How to Remove scratches from a CD: étape 4, image 3 de 3
    • Take the toothpaste, and apply it to your index finger.
    • Rinse the toothpaste in lukewarm water and apply to the CD.
    • Rub toothpaste in a circular motion from the center to the outer edge.
    • Add multiple layers of toothpaste to cover all of the scratches.
    • Use a white toothpaste, not a gel. Gels containing little beads may cause more damage to the CD.
  5. How to Remove scratches from a CD: étape 5, image 1 de 1
    • Let the CD sit for 2 to 3 minutes.
  6. How to Remove scratches from a CD: étape 6, image 1 de 1
    • Rinse off the toothpaste with lukewarm water.
  7. How to Remove scratches from a CD: étape 7, image 1 de 1
    • Let the CD air dry, or dry with a non-linen towel.
  8. How to Remove scratches from a CD: étape 8, image 1 de 1
    • Inspect your disk.
    • If your disk still has scratches, repeat the process.
    • You could also try to burn the disk onto another disk if the disk is lagging.
40 autres ont terminé cette réparation.
Nick Jones
Membre depuis le 09/29/15
1 389 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 14-4, Green Fall 2015 Membre de l'équipe Cal Poly, Team 14-4, Green Fall 2015
CPSU-GREEN-F15S14G4
5 membres
16 tutoriels rédigés
5 commentaires
thank youuuuuuuuu
aboabdo.2007 - Réponse
Funziona anche con i DVD di film e videogiochi questo procedimento? Oppure è solo specifico per i CD?
Francesco Pepe - Réponse
It did not work for me
Leisy Madrigal - Réponse
Me Funciono muy bien, gracias!
Esteban Montero - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 52
7 derniers jours : 317
30 derniers jours : 1,250
Total : 57,389
