Introduction
Removing the back plate will allow access to the inner circuitry of the calculator, which is necessary for other troubleshooting guides.
Outils
Pièces
Aucune pièce spécifiée.
Place the calculator screen facing down with the back plate facing up.
Now, turn the calculator over so the back plate faces up.
Use the Plastic Prying Tool to carefully pry the back plate out at the bottom right corner.
Repeat the prying step on the right side, moving along the perimeter of the calculator.
Repeat the prying step on the top right corner.
To reassemble your device, carefully push the back plate back onto the calculator. Then replace the screws back into the back plate.
