Aller au contenu principal
How to Repair A Hole In Curtains
Ce dont vous avez besoin
  1. How to Repair A Hole In Curtains, How to Repair A Hole In Curtains: étape 1, image 1 de 2 How to Repair A Hole In Curtains, How to Repair A Hole In Curtains: étape 1, image 2 de 2
    • Examine the hole and open it gently so as to not cause any tearing.
    • Cut any loose threads that have frayed around the tear.
    • Be careful when using scissors. They are sharp and may cause injury.
  2. How to Repair A Hole In Curtains: étape 2, image 1 de 2 How to Repair A Hole In Curtains: étape 2, image 2 de 2
    • Use your scissors to cut a piece of fusible interfacing.
    • Make sure this piece is slightly larger than the hole in your curtain.
  3. How to Repair A Hole In Curtains: étape 3, image 1 de 1
    • Place the ripped curtain face down on the ironing board.
  4. How to Repair A Hole In Curtains: étape 4, image 1 de 2 How to Repair A Hole In Curtains: étape 4, image 2 de 2
    • Place the fusible interfacing adhesive side down.
    • This side will have raised bumps on it
  5. How to Repair A Hole In Curtains: étape 5, image 1 de 1
    • Preheat the iron to the temperature stated on the instructions for the fusible interfacing.
    • Some fusible interfacing may require either a steam setting or a dry setting.
  6. How to Repair A Hole In Curtains: étape 6, image 1 de 3 How to Repair A Hole In Curtains: étape 6, image 2 de 3 How to Repair A Hole In Curtains: étape 6, image 3 de 3
    • Iron over the interfacing until it sticks to the fabric.
    • If the fabric is delicate you may want to place a protective cloth over the patch before ironing.
    • Be careful when using an iron. They can burn the fabric or cause serious injury.
Now your curtain is as good as new! Fusible interfacing cannot be removed once it is attached to the fabric, so be careful when applying it so you can repair your curtains successfully.
Heather Brody
Membre depuis le 03/29/21
133 Réputation
1 tutoriel rédigé
Équipe
Marist, Team S1-G4, Chaterdon Spring 2021 Membre de l'équipe Marist, Team S1-G4, Chaterdon Spring 2021
MARS-CHATERDON-S21S1G4
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 19
30 derniers jours : 75
Total : 2,375
