Aller au contenu principal
How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On
Ce dont vous avez besoin
Vidéo d'introduction
  1. How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On: étape 1, image 1 de 1
    • As you can see from the photo, the negative pole of the battery is connected to the main board through the aluminum body of the keyboard.
    • There are two contact areas:
    • Between the battery cover and the KB aluminum body
    • Between the power button assemble and the KB aluminum body
    • If the device has a power problem, we need to check and clean these two places
  2. How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Battery replacement: étape 2, image 1 de 3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Battery replacement: étape 2, image 2 de 3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Battery replacement: étape 2, image 3 de 3
    • Use a Coin to remove the metal battery screw cover
    • Change the batteries (AA) and test the keyboard
    • If the keyboard does not work, go to the next step
  3. How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Cleaning battery cover area: étape 3, image 1 de 3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Cleaning battery cover area: étape 3, image 2 de 3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Cleaning battery cover area: étape 3, image 3 de 3
    • Use cotton buds, Toothpicks and Isopropyl Alcohol to clean the contact area and the battery cap.
    • Test the device and f the keyboard does not work, go to the next step
  4. How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Logic Board Removal Part 1: étape 4, image 1 de 3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Logic Board Removal Part 1: étape 4, image 2 de 3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Logic Board Removal Part 1: étape 4, image 3 de 3
    • Remove the plastic cap from the middle on the tube and disconnect the KB flex cable
    • There are a screw secured the BT antenna, remove it
    • Slide the board out.
    • Be careful for the KB Flex Cable
  5. How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On: étape 5, image 1 de 3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On: étape 5, image 2 de 3 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On: étape 5, image 3 de 3
    • Use tweezers or a sharp metal tool and slightly bend the contact plate outwards
    • Clean the tube and the contact plate
    • Install back the logic board plate and be careful for the flex
5 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
190 079 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
319 membres
1 353 tutoriels rédigés
4 commentaires
Add a little dielectric grease to the battery end cap. Had considerable corrosion despite batteries not leaking. Strange design.
George Walsh - Réponse
Wow! This fixed actually worked! I was about to thrown this A1314 keyboard out (2009 model)! You can remove the plastic "cap" with a precision flathead screwdriver. Also, be careful when disassembling the ribbon cable - there is a plastic retaining clip holding it in place. Use the precision screwdriver to carefully release the tabs on either side and then pop it out. The ribbon cable will then easily side out. By the way...I'm typing this comment on my newly fixed wireless keyboard! Thanks again!
Vic - Réponse
its great having this guide. I got the keyboard to work again.
shinnranchgrouse - Réponse
from time to time it makes error sound and interfering apps such as blinking pop up menus ... speaking about MacBook Pro 2017 Monterey
Not to mention that it's not connecting to MacBook Air M1 at all ... )) Goodby my 2009 bluetooth .. Sad ..It is like new and working with other apps except adobe )
Alec - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 54
30 derniers jours : 245
Total : 12,466
