Aller au contenu principal
How to Repair Corners of Drywall
Ce dont vous avez besoin
  1. How to Repair Corners of Drywall, How to Repair Corners of Drywall: étape 1, image 1 de 3 How to Repair Corners of Drywall, How to Repair Corners of Drywall: étape 1, image 2 de 3 How to Repair Corners of Drywall, How to Repair Corners of Drywall: étape 1, image 3 de 3
    • Measure top and bottom of damaged section.
    • When replacing a corner bead, you must measure at least 1.5 inches from the corner.
    • Use a straight edge between the the top and bottom and draw a straight-line connecting the marking.
    • You can even use the putty knife if the damaged section is not too long.
    • Mark with a pencil, or cut lightly with utility knife.
    • Use caution when using the utility knife as the blade is very sharp and may cause an injury.
  2. How to Repair Corners of Drywall: étape 2, image 1 de 2 How to Repair Corners of Drywall: étape 2, image 2 de 2
    • Using your putty knife, dig out of the spackle inside your marking.
    • You need to get down to the metal, or vinyl corner drywall bead.
    • Use caution to not dig too deep.
  3. How to Repair Corners of Drywall: étape 3, image 1 de 1
    • Unscrew screws in the section of bead that you are going to remove.
    • If it is a vinyl corner bead, then break taped underside with corner of putty knife carefully.
    • Cut the metal corner bead with tin snips.
    • If Vinyl, then use your utility knife.
    • Measure new corner bead and cut.
    • Place new corner bead on corner and fasten in place using screws or tape.
  4. How to Repair Corners of Drywall: étape 4, image 1 de 1
    • Apply joint compound with a 4 inch putty knife.
    • The more compound the better. It will shrink while drying.
    • Do not worry about getting corners the perfect.
    • Dry for 12 hours.
  5. How to Repair Corners of Drywall: étape 5, image 1 de 3 How to Repair Corners of Drywall: étape 5, image 2 de 3 How to Repair Corners of Drywall: étape 5, image 3 de 3
    • Sand area with 80 grit sandpaper.
    • Wipe down with damp cloth, sponge, or paper towel.
    • Be careful to not wet down the patch with too much water. Only minimum amount of dampness needed to wipe away sanding dust.
    • Apply thinner coat of joint compound with a 6, or 8 inch putty knife.
    • Pay attention to put pressure on the outside edge.
    • Let dry for 2 hours.
  6. How to Repair Corners of Drywall: étape 6, image 1 de 1
    • Sand the area with 120 grit sandpaper.
    • If needed, repeat Step 5 again.
    • Paint the patched area to match wall
Now the corner drywall is ready to be painted and match the rest of the room.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 125
Total : 20,053
