Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Repair Cracks in T-Shirt Print
Ce dont vous avez besoin
  1. How to Repair Cracks in T-Shirt Print, How to Repair Cracks in T-Shirt Print: étape 1, image 1 de 3 How to Repair Cracks in T-Shirt Print, How to Repair Cracks in T-Shirt Print: étape 1, image 2 de 3 How to Repair Cracks in T-Shirt Print, How to Repair Cracks in T-Shirt Print: étape 1, image 3 de 3
    • Lay your shirt on a flat surface.
    • Use scissors to cut a piece of parchment paper the same size as the design on your shirt.
    • Insert the piece of parchment paper inside of the shirt and under the design.
    • This is to prevent the acetone from staining.
    Demander à FixBot
    Ajouter un commentaire
  2. How to Repair Cracks in T-Shirt Print: étape 2, image 1 de 3 How to Repair Cracks in T-Shirt Print: étape 2, image 2 de 3 How to Repair Cracks in T-Shirt Print: étape 2, image 3 de 3
    • Dampen a cotton ball with the acetone.
    • Gently dab the cotton ball onto the cracked area of the shirt and hold it in place for 1 minute.
    • Remember to always dab, do not rub.
    • Repeat this over the whole area that you wish to restore.
    • Let your shirt set for 3-5 minutes
    • If you're doing a small area, let it set for 2-3 minutes. If it is any bigger, set it for 5 minutes.
    Demander à FixBot
  3. How to Repair Cracks in T-Shirt Print: étape 3, image 1 de 3 How to Repair Cracks in T-Shirt Print: étape 3, image 2 de 3 How to Repair Cracks in T-Shirt Print: étape 3, image 3 de 3
    • Cut a piece of parchment paper to match the size of the shirt's design, then place it over the design.
    • Turn on a clothes iron to the highest heat setting with NO steam.
    • Be careful when handling the iron, it gets burning hot!
    • When your iron is ready, place it over the parchment paper and go over the whole design once.
    • Go over the areas that had the cracks for at least 10-15 seconds.
    Demander à FixBot
  4. How to Repair Cracks in T-Shirt Print: étape 4, image 1 de 1
    • Now your shirt design should no longer have cracks.
    Demander à FixBot
Ligne d'arrivée
Sitara Cruz-Cuevas
Membre depuis le 10/14/24
155 Réputation
1 tutoriel rédigé
Équipe
Austin Community College, Team 29-4, Watkins Fall 2024 Membre de l'équipe Austin Community College, Team 29-4, Watkins Fall 2024
AUSTINCC-WATKINS-F24S29G4
1 membre
2 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 34
7 derniers jours : 236
30 derniers jours : 1,227
Total : 8,451
