Aller au contenu principal
How to Repair Frayed Shoelaces
Ce dont vous avez besoin
  1. How to Repair Frayed Shoelaces, How to Repair Frayed Shoelaces: étape 1, image 1 de 1
    • Cut of the excess frayed shoelace.
  2. How to Repair Frayed Shoelaces: étape 2, image 1 de 3 How to Repair Frayed Shoelaces: étape 2, image 2 de 3 How to Repair Frayed Shoelaces: étape 2, image 3 de 3
    • Slip the entire heat shrink tube over the frayed part of the lace.
    • Make sure to clump the frayed part of the lace together when inserting the tubing.
    • Do not cover too much of the lace that is not frayed with tubing as that could result in unwanted indents in the shoelace.
  3. How to Repair Frayed Shoelaces: étape 3, image 1 de 2 How to Repair Frayed Shoelaces: étape 3, image 2 de 2
    • After slipping the tube on, grab the scissors and trim the excess tubing to the length of your satisfaction.
    • Remember not to go beyond the frayed part of the lace with tubing.
  4. How to Repair Frayed Shoelaces: étape 4, image 1 de 3 How to Repair Frayed Shoelaces: étape 4, image 2 de 3 How to Repair Frayed Shoelaces: étape 4, image 3 de 3
    • Now use the lighter and heat the heat shrink tube, about an inch away from the lace, until the tube becomes compressed all the way around.
    • Make sure to heat the heat shrink tube all the way around, heating the entire tube
    • When heating, always keep moving the lighter all around and not staying on one part of the tube for too long.
  5. How to Repair Frayed Shoelaces: étape 5, image 1 de 1
    • Repeat these steps on all the other frayed shoelaces.
When the heat shrink tube is completely shrunk to appropriate size, you are finished. Repeat steps 1-4 depending on how many frayed laces are present.
14 autres ont terminé cette réparation.
Anirudh Jain
Membre depuis le 04/09/15
605 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 28-6, Green Spring 2015 Membre de l'équipe Cal Poly, Team 28-6, Green Spring 2015
CPSU-GREEN-S15S28G6
4 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 43
Total : 11,852
