Aller au contenu principal
How to Repair LP Record Playing Surface
Ce dont vous avez besoin
  1. How to Repair LP Record Playing Surface, How to Repair LP Record Playing Surface: étape 1, image 1 de 1
    • Create a solution of 2 parts water to 1 part rubbing alcohol.
    • Using a paper towel, lightly brush the record with this solution.
  2. How to Repair LP Record Playing Surface: étape 2, image 1 de 1
    • Apply enough wood glue to cover the record's surface.
  3. How to Repair LP Record Playing Surface: étape 3, image 1 de 1
    • Place the record on a record player, then turn on the record player so it rotates.
    • With a note card, apply the wood glue so that it covers the entire record surface.
    • Avoid getting glue on the record's label, as this will damage the label once the glue dries.
  4. How to Repair LP Record Playing Surface: étape 4, image 1 de 1
    • Place a strip of tape on the wet wood glue.
    • This will act as a handle later to remove the dried wood glue.
  5. How to Repair LP Record Playing Surface: étape 5, image 1 de 1
    • Turn the record player off after you apply the wood glue.
    • Let the record sit for 12 hours to dry.
  6. How to Repair LP Record Playing Surface: étape 6, image 1 de 1
    • After 12 hours, check to see the wood glue has dried.
    • If it has dried, use the tape as a “handle” to peel the glue off.
    • If the wood glue is not yet dry, check back once every hour until it has dried.
  7. How to Repair LP Record Playing Surface: étape 7, image 1 de 1
    • Repeat steps 1-6 on the opposite side of the LP if necessary.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Connor Enos
Membre depuis le 07/03/18
205 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 16
30 derniers jours : 53
Total : 1,572
