Aller au contenu principal
How to Repair Water Damage Under Your Sink
Ce dont vous avez besoin
  1. How to Repair Water Damage Under Your Sink, How to Repair Water Damage Under Your Sink: étape 1, image 1 de 3 How to Repair Water Damage Under Your Sink, How to Repair Water Damage Under Your Sink: étape 1, image 2 de 3 How to Repair Water Damage Under Your Sink, How to Repair Water Damage Under Your Sink: étape 1, image 3 de 3
    • Remove all items from under your sink.
    • Test for water leaks by gently pressing the cabinet with your fingers and seeing if it's wet and by looking for drips from the sink.
    • Clean the cabinet using a sponge or cloth with a cleaner or disinfectant of your choice.
  2. How to Repair Water Damage Under Your Sink: étape 2, image 1 de 3 How to Repair Water Damage Under Your Sink: étape 2, image 2 de 3 How to Repair Water Damage Under Your Sink: étape 2, image 3 de 3
    • Use work gloves to sand the cabinet.
    • Use 100-grit sandpaper to sand the interior of the cabinets using a circular motion.
    • Sand until you can move your hand across the cabinet, and it feels smooth.
    • Clean the sand dust from the cabinet with a damp cloth or sponge.
  3. How to Repair Water Damage Under Your Sink: étape 3, image 1 de 3 How to Repair Water Damage Under Your Sink: étape 3, image 2 de 3 How to Repair Water Damage Under Your Sink: étape 3, image 3 de 3
    • Apply wood filler with a paint tool making sure you don't apply too much of the filler.
    • You want the layer of filler to be smooth for when you paint over it later.
    • Use painter's tape to mark the areas that you don't want paint on.
  4. How to Repair Water Damage Under Your Sink: étape 4, image 1 de 3 How to Repair Water Damage Under Your Sink: étape 4, image 2 de 3 How to Repair Water Damage Under Your Sink: étape 4, image 3 de 3
    • Use a caulking gun to seal the edges of the base. Gently press down on the applicator and follow the perimeter of the cabinet.
    • Use your finger to wipe all excess caulk off.
    • Let it dry for 30 minutes.
  5. How to Repair Water Damage Under Your Sink: étape 5, image 1 de 3 How to Repair Water Damage Under Your Sink: étape 5, image 2 de 3 How to Repair Water Damage Under Your Sink: étape 5, image 3 de 3
    • Use an angle brush to paint all the edges with primer.
    • Use a roller to paint the rest of the cabinet with primer.
    • Let it dry for 1 hour or until it is completely dry.
  6. How to Repair Water Damage Under Your Sink: étape 6, image 1 de 3 How to Repair Water Damage Under Your Sink: étape 6, image 2 de 3 How to Repair Water Damage Under Your Sink: étape 6, image 3 de 3
    • Use an angle brush to paint all the edges with the paint of your choice.
    • Use the roller to complete painting the cabinet.
    • Let the paint dry.
    • Place your items back under the sink.
Now, you've got a good-as-new cabinet! You can reapply as needed if paint chips or dulls.
Chelsea Trevino
Membre depuis le 09/24/23
133 Réputation
1 tutoriel rédigé
Équipe
Austin Community College, Team 1-12, Watkins Fall 2023 Membre de l'équipe Austin Community College, Team 1-12, Watkins Fall 2023
AUSTINCC-WATKINS-F23S1G12
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 23
30 derniers jours : 163
Total : 998
