Aller au contenu principal
How to Repair a Bra Underwire
Ce dont vous avez besoin
  1. How to Repair a Bra Underwire, How to Repair a Bra Underwire: étape 1, image 1 de 3 How to Repair a Bra Underwire, How to Repair a Bra Underwire: étape 1, image 2 de 3 How to Repair a Bra Underwire, How to Repair a Bra Underwire: étape 1, image 3 de 3
    • Push the underwire into the hole until it is no longer visible.
  2. How to Repair a Bra Underwire: étape 2, image 1 de 3 How to Repair a Bra Underwire: étape 2, image 2 de 3 How to Repair a Bra Underwire: étape 2, image 3 de 3
    • Thread the needle.
    • Pull the thread to a length of about 8 inches.
    • Match the length of the thread on each side of the loop and cut with the scissors.
    • Doubling up the thread in this way allows for stronger and longer-lasting stitches.
  3. How to Repair a Bra Underwire: étape 3, image 1 de 3 How to Repair a Bra Underwire: étape 3, image 2 de 3 How to Repair a Bra Underwire: étape 3, image 3 de 3
    • Loop both ends of the thread around your index finger.
    • Pinch the ends of the thread between your index finger and thumb and roll your index finger downwards until the loop slips off.
    • Carefully take hold of the loop and pull to create a knot.
    • Sometimes the knot created the first time may not be large enough. Repeat the last three instructions a second time to make a larger knot.
  4. How to Repair a Bra Underwire: étape 4, image 1 de 3 How to Repair a Bra Underwire: étape 4, image 2 de 3 How to Repair a Bra Underwire: étape 4, image 3 de 3
    • Insert the needle just above the tear in the bra where the underwire came out.
    • This ensures that the hole will not expand any further and provides extra stability in the stitches.
    • Handle the needle with care to not accidentally injure yourself!
  5. How to Repair a Bra Underwire: étape 5, image 1 de 2 How to Repair a Bra Underwire: étape 5, image 2 de 2
    • Use a whip stitch to mend the tear.
    • Pull the needle through the fabric until the knot at the end of the thread approaches the incision.
    • On the opposite side, insert the needle again at a point just after the first incision and pull it through the fabric.
    • Continue this pattern two or three stitches below the tear.
  6. How to Repair a Bra Underwire: étape 6, image 1 de 2 How to Repair a Bra Underwire: étape 6, image 2 de 2
    • Repeat the process from Step 4 going back upwards towards the tear, over your current stitching.
    • This gives your stitches extra reinforcement to make sure the tear is not reopened or pushes through the stitches.
  7. How to Repair a Bra Underwire: étape 7, image 1 de 3 How to Repair a Bra Underwire: étape 7, image 2 de 3 How to Repair a Bra Underwire: étape 7, image 3 de 3
    • Close the stitch.
    • Near your first incision, where the knot is, insert the needle into the fabric halfway through.
    • Wind the leftover thread around the sharp end of the needle 3-4 times, then pull the needle through completely.
    • Tug on the needle upwards to tighten the knot created.
  8. How to Repair a Bra Underwire: étape 8, image 1 de 3 How to Repair a Bra Underwire: étape 8, image 2 de 3 How to Repair a Bra Underwire: étape 8, image 3 de 3
    • Trim the thread with scissors. Leave a few millimeters of thread leftover to ensure that the knot does not come loose.
    • Optional: use a small amount of fabric adhesive over the stitching to fully reinforce it and seal the tear.
    • Leave it without glue and you are done.
Wear your bra a few times to make sure the underwire doesn't force its way out again. If it does, use tighter stitches and sew them a little closer together.
Cody Gunderson
Membre depuis le 04/28/17
107 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team S1-G2, Coad Spring 2017 Membre de l'équipe UC Davis, Team S1-G2, Coad Spring 2017
UCD-COAD-S17S1G2
4 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 5
30 derniers jours : 32
Total : 4,239
