Aller au contenu principal
How to Repair a Broken Huggie Earring Clasp
Ce dont vous avez besoin
  1. How to Repair a Broken Huggie Earring Clasp, How to Repair a Broken Huggie Earring Clasp: étape 1, image 1 de 1
    • Clean the post and clasp of the earring with a dry cloth.
  2. How to Repair a Broken Huggie Earring Clasp: étape 2, image 1 de 2 How to Repair a Broken Huggie Earring Clasp: étape 2, image 2 de 2
    • Close the earring and note where the main post hits the notch on the opposite side.
    • There are two notches, one on the main post and one on the opposite side of the earring.
  3. How to Repair a Broken Huggie Earring Clasp: étape 3, image 1 de 1
    • Mark this spot with a writing instrument (optional).
  4. How to Repair a Broken Huggie Earring Clasp: étape 4, image 1 de 1
    • Re-open the earring.
  5. How to Repair a Broken Huggie Earring Clasp: étape 5, image 1 de 3 How to Repair a Broken Huggie Earring Clasp: étape 5, image 2 de 3 How to Repair a Broken Huggie Earring Clasp: étape 5, image 3 de 3
    • Ensure the post is lined up with the opposite notch. If not, gently bend it with your finger until it is in a suitable position.
  6. How to Repair a Broken Huggie Earring Clasp: étape 6, image 1 de 1
    • Grip the earring post with a small plier or tweezer and push the post slightly upward.
  7. How to Repair a Broken Huggie Earring Clasp: étape 7, image 1 de 2 How to Repair a Broken Huggie Earring Clasp: étape 7, image 2 de 2
    • Open to check if the earring clicks.
  8. How to Repair a Broken Huggie Earring Clasp: étape 8, image 1 de 1
    • If the earring isn’t clicking, push the post further upward using pliers.
    • Adjust, then check again.
  9. How to Repair a Broken Huggie Earring Clasp: étape 9, image 1 de 1
    • If the earring clicks but is hard to open, push the post downward using pliers.
    • This is an adjustment process, so make small adjustments until it is restored.
  10. How to Repair a Broken Huggie Earring Clasp: étape 10, image 1 de 1
    • Make final adjustments until the huggie clasp clicks and the earring closes securely.
    • Wipe the marker off of your earring.
Your earring is now fixed! If the post bends again, repeat the same steps to repair.
Hana Ito
Membre depuis le 04/26/24
181 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 4-6, Whithaus Spring 2024 Membre de l'équipe UC Davis, Team 4-6, Whithaus Spring 2024
UCD-WHITHAUS-S24S4G6
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 18
Total : 58
