Aller au contenu principal
How to Repair a Crack on a Vittorazi Moster Exhaust
Ce dont vous avez besoin
  1. How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: étape 1, image 1 de 3 How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: étape 1, image 2 de 3 How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: étape 1, image 3 de 3
    • Use a 10mm open wrench to lossen the three exhaust mounting points.
    • Locate the nuts that need to be adjusted and make sure you you have the proper tools, stated earlier to ensure they can loosen.
    • Once you have found the nuts, use your 10mm wrench to carefully unscrew and loosen the nuts.
    • This may take some extra force to loosen the nuts, and if this is case, keep in mind all safety precautions.
  2. How to Repair a Crack on a Vittorazi Moster Exhaust: étape 5, image 1 de 2 How to Repair a Crack on a Vittorazi Moster Exhaust: étape 5, image 2 de 2
    • Remove with the 10mm wrench the two nuts in the exhaust base.
  3. How to Repair a Crack on a Vittorazi Moster Exhaust: étape 6, image 1 de 1
    • Remove the loosen mounts and take out the exhaust with it's base.
  4. How to Repair a Crack on a Vittorazi Moster Exhaust: étape 7, image 1 de 1
    • Clean the cracked area with alcohol and a rug.
  5. How to Repair a Crack on a Vittorazi Moster Exhaust: étape 8, image 1 de 2 How to Repair a Crack on a Vittorazi Moster Exhaust: étape 8, image 2 de 2
    • Grind the cracked area with the grinder.
  6. How to Repair a Crack on a Vittorazi Moster Exhaust: étape 9, image 1 de 2 How to Repair a Crack on a Vittorazi Moster Exhaust: étape 9, image 2 de 2
    • Weld the cracked area with the welder.
  7. How to Repair a Crack on a Vittorazi Moster Exhaust: étape 10, image 1 de 2 How to Repair a Crack on a Vittorazi Moster Exhaust: étape 10, image 2 de 2
    • Grind the welded area with the grinder to smooth the area.
  8. How to Repair a Crack on a Vittorazi Moster Exhaust: étape 11, image 1 de 1
    • Reinstall the exhaust to the motor by repeating 1-3 steps in reverse order.
Ligne d'arrivée
Darrell Gonzalez
Membre depuis le 09/20/21
207 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 21
Total : 1,098
