Aller au contenu principal
How to Repair a Damaged Steelcase Cachet Chair Armrest
Ce dont vous avez besoin
  1. How to Repair a Damaged Steelcase Cachet Chair Armrest, How to Repair a Damaged Steelcase Cachet Chair Armrest: étape 1, image 1 de 3 How to Repair a Damaged Steelcase Cachet Chair Armrest, How to Repair a Damaged Steelcase Cachet Chair Armrest: étape 1, image 2 de 3 How to Repair a Damaged Steelcase Cachet Chair Armrest, How to Repair a Damaged Steelcase Cachet Chair Armrest: étape 1, image 3 de 3
    • Use an iFixit Opening Tool to remove the broken piece from your cracked armrest.
    • Avoid the jagged edges of plastic as they are sharp and could cut or scrape the skin.
  2. How to Repair a Damaged Steelcase Cachet Chair Armrest: étape 2, image 1 de 2 How to Repair a Damaged Steelcase Cachet Chair Armrest: étape 2, image 2 de 2
    • Use sandpaper to lightly sand the edges of the broken piece of arm rest.
    • Remove any remaining debris from the armrest.
  3. How to Repair a Damaged Steelcase Cachet Chair Armrest: étape 3, image 1 de 2 How to Repair a Damaged Steelcase Cachet Chair Armrest: étape 3, image 2 de 2
    • Wear gloves! The putty is toxic!
    • Cut or pull off a small section of putty.
    • Knead the putty in your hands for 30-60 seconds until it is a uniform color.
  4. How to Repair a Damaged Steelcase Cachet Chair Armrest: étape 4, image 1 de 1
    • Work quickly! The putty will begin to harden in 5 minutes!
    • Apply a small amount of putty on the inside of the hollow space of the armrest.
    • The putty will act as a support for the broken piece.
    • Repeat Step 3 to use as many pieces of putty as needed.
  5. How to Repair a Damaged Steelcase Cachet Chair Armrest: étape 5, image 1 de 1
    • Apply putty along the edges of the broken piece.
  6. How to Repair a Damaged Steelcase Cachet Chair Armrest: étape 6, image 1 de 2 How to Repair a Damaged Steelcase Cachet Chair Armrest: étape 6, image 2 de 2
    • Set the broken piece back onto the armrest.
    • Try to make the broken piece level with the rest of the armrest, as this will make Steps 7 & 8 easier.
    • Let the putty dry for about 10 minutes.
  7. How to Repair a Damaged Steelcase Cachet Chair Armrest: étape 7, image 1 de 2 How to Repair a Damaged Steelcase Cachet Chair Armrest: étape 7, image 2 de 2
    • Apply the plastic putty over the broken piece.
    • Press putty into any remaining empty spaces.
    • Repeat Step 3 as many times as needed.
    • Let the putty dry for 10 minutes in between applications.
  8. How to Repair a Damaged Steelcase Cachet Chair Armrest: étape 8, image 1 de 2 How to Repair a Damaged Steelcase Cachet Chair Armrest: étape 8, image 2 de 2
    • Sand down the putty covering to make the surface smooth and level with the armrest.
    • Paint-match the color of the chair and paint over the putty for a cosmetically seamless result.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Henry Xu
Membre depuis le 04/26/24
169 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 4-5, Whithaus Spring 2024 Membre de l'équipe UC Davis, Team 4-5, Whithaus Spring 2024
UCD-WHITHAUS-S24S4G5
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 34
Total : 101
