Aller au contenu principal
How to Repair a Dangle Earring
Ce dont vous avez besoin
  1. How to Repair a Dangle Earring, How to Repair a Dangle Earring: étape 1, image 1 de 1
    • Clean the jump ring of the earring and the earring itself.
    • This step is optional.
  2. How to Repair a Dangle Earring: étape 2, image 1 de 2 How to Repair a Dangle Earring: étape 2, image 2 de 2
    • Take the jump ring with the two small needle-nose pliers.
    • Gently open the jump ring using the needle nose pliers.
  3. How to Repair a Dangle Earring: étape 3, image 1 de 2 How to Repair a Dangle Earring: étape 3, image 2 de 2
    • Take the top part of the earring with your dominant hand.
    • Put the jump ring through the top part of the earring.
    • You can hold the jump ring with a small needle-nose pliers with your non-dominant hand.
  4. How to Repair a Dangle Earring: étape 4, image 1 de 2 How to Repair a Dangle Earring: étape 4, image 2 de 2
    • Pass the earring through the opening of the jump ring.
    • Make sure that both parts of the earring face the same direction.
  5. How to Repair a Dangle Earring: étape 5, image 1 de 2 How to Repair a Dangle Earring: étape 5, image 2 de 2
    • To close the jump ring, use both of the needle nose pliers.
    • Use your dominant hand to close the space in the jump ring.
    • Try to keep your non-dominant hand still.
  6. How to Repair a Dangle Earring: étape 6, image 1 de 2 How to Repair a Dangle Earring: étape 6, image 2 de 2
    • Make sure that the jump ring is closed.
    • Hold the earring up to make sure it's secure.
To just change a clasp that it was not broken, follow these instructions in reverse order.
Sabrina L. Martínez Ortiz
Membre depuis le 03/18/22
133 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 21
Total : 1,181
