Introduction
Use this guide to repair a power supply cable that has frayed at the power inlet.
Ce dont vous avez besoin
Inspect the frayed power supply end for spots that you can cut off the connector insulation without damaging the wires.
Cut the insulation off the connector using wire cutters, scissors, or a sharp knife.
Open the Sugru pack, remove the material, and press it around the connector to make a new connector insulator. It is recommended that your new sheath extends at least .5" past the damaged area.
You have approximately 30 minutes to work the Sugru. Then allow about 24 hours for it to fully cure.
29 autres ont terminé cette réparation.
