Aller au contenu principal
How to Repair a Knotted Chain
Ce dont vous avez besoin
  1. How to Repair a Knotted Chain, How to Repair a Knotted Chain: étape 1, image 1 de 1
    • Find a flat surface.
    • Remove all clutter from your workspace to ensure you can access the chain easily.
    • The flat surface will provide stability when you begin working through the tangles and will prevent other tangles from forming during the process.
  2. How to Repair a Knotted Chain: étape 2, image 1 de 3 How to Repair a Knotted Chain: étape 2, image 2 de 3 How to Repair a Knotted Chain: étape 2, image 3 de 3
    • Rest the chain on the surface.
    • Slowly spread the chain out so you can recognize the tangled areas.
    • While spreading the chain on the surface, make sure to do so slowly in order to avoid tightening the tangle.
  3. How to Repair a Knotted Chain: étape 3, image 1 de 3 How to Repair a Knotted Chain: étape 3, image 2 de 3 How to Repair a Knotted Chain: étape 3, image 3 de 3
    • Unclasp the chain.
    • Separate the strands gently.
    • Opening the clasp will isolate the chain strands, permitting them to slide through the knots easily.
  4. How to Repair a Knotted Chain: étape 4, image 1 de 2 How to Repair a Knotted Chain: étape 4, image 2 de 2
    • Gently sprinkle baby powder onto the knotted area.
    • Sprinkle the powder until the knot is lightly coated.
    • This is an optional step.
  5. How to Repair a Knotted Chain: étape 5, image 1 de 3 How to Repair a Knotted Chain: étape 5, image 2 de 3 How to Repair a Knotted Chain: étape 5, image 3 de 3
    • Bring your thumb and index finger into a pinching pose.
    • Put the knot between the thumb and index finger.
    • Carefully and gently lightly rub the knot together.
  6. How to Repair a Knotted Chain: étape 6, image 1 de 2 How to Repair a Knotted Chain: étape 6, image 2 de 2
    • Insert two toothpicks between the focal point of the knot.
    • Any fine toothpick style tool can work to untangle the knot.
  7. How to Repair a Knotted Chain: étape 7, image 1 de 3 How to Repair a Knotted Chain: étape 7, image 2 de 3 How to Repair a Knotted Chain: étape 7, image 3 de 3
    • Gently draw the toothpicks from one another to open and release the tight knot.
    • When you get an opening in the knot using the toothpicks, take it apart by pulling each separated strand through the knot to fully open it.
    • Then slowly pull apart the loosened knot to separate the chain strands.
  8. How to Repair a Knotted Chain: étape 8, image 1 de 2 How to Repair a Knotted Chain: étape 8, image 2 de 2
    • Restore chain back into its original form.
    • Clasp the chain to avoid it from re-tangling.
  9. How to Repair a Knotted Chain: étape 9, image 1 de 2 How to Repair a Knotted Chain: étape 9, image 2 de 2
    • Wipe the chain with a damp towel or tissue before use.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Momena Masood
Membre depuis le 05/10/20
223 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G19, O'Regan Summer 2020 Membre de l'équipe York University, Team S1-G19, O'Regan Summer 2020
YORK-O'REGAN-SU20S1G19
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 568
