Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Repair a Leather Jacket Pocket
Ce dont vous avez besoin
  1. How to Repair a Leather Jacket Pocket, How to Repair a Leather Jacket Pocket: étape 1, image 1 de 3 How to Repair a Leather Jacket Pocket, How to Repair a Leather Jacket Pocket: étape 1, image 2 de 3 How to Repair a Leather Jacket Pocket, How to Repair a Leather Jacket Pocket: étape 1, image 3 de 3
    • Lay the jacket flat and gather your scissors, needle, and thread.
    • If your jacket has a thicker material, you may consider using a thicker leather needle.
    • Be careful not to prick your fingers with the sharp tools listed above.
    Demander à FixBot
    Ajouter un commentaire
  2. How to Repair a Leather Jacket Pocket: étape 2, image 1 de 2 How to Repair a Leather Jacket Pocket: étape 2, image 2 de 2
    • Insert thread inside the eye of the needle.
    • Measure thread out to two times the length that you need and then use scissors to cut the thread.
    • We used white thread for this guide, but any color of thread will work for this project.
    Demander à FixBot
  3. How to Repair a Leather Jacket Pocket: étape 3, image 1 de 3 How to Repair a Leather Jacket Pocket: étape 3, image 2 de 3 How to Repair a Leather Jacket Pocket: étape 3, image 3 de 3
    • Tie a knot using the two ends of the thread.
    • Repeat this knot 3 times in the same spot.
    Demander à FixBot
  4. How to Repair a Leather Jacket Pocket: étape 4, image 1 de 3 How to Repair a Leather Jacket Pocket: étape 4, image 2 de 3 How to Repair a Leather Jacket Pocket: étape 4, image 3 de 3
    • At the end of the tear, insert the needle inside of the fabric's right side and pull to tighten.
    • Then, insert the needle through the front of the fabric and pull to tighten to make your first stitch.
    • You can use a safety pin to hold your fabric together if needed.
    Demander à FixBot
  5. How to Repair a Leather Jacket Pocket: étape 5, image 1 de 2 How to Repair a Leather Jacket Pocket: étape 5, image 2 de 2
    • Now that your thread is facing the inside of the fabric, insert your needle into the first layer of the left side of the fabric.
    • Weave your needle up and out through this layer and pull to tighten.
    • The thread should not be visible on the outside of the left fabric.
    Demander à FixBot
  6. How to Repair a Leather Jacket Pocket: étape 6, image 1 de 3 How to Repair a Leather Jacket Pocket: étape 6, image 2 de 3 How to Repair a Leather Jacket Pocket: étape 6, image 3 de 3
    • Insert your needle into the inside of the right side of the fabric and pull to tighten. This completes your first stitch.
    Demander à FixBot
  7. How to Repair a Leather Jacket Pocket: étape 7, image 1 de 2 How to Repair a Leather Jacket Pocket: étape 7, image 2 de 2
    • To start your next stitch, insert the needle 1cm above the last puncture.
    • Repeat steps 4 through 6 until you reach the end of your tear.
    Demander à FixBot
  8. How to Repair a Leather Jacket Pocket: étape 8, image 1 de 3 How to Repair a Leather Jacket Pocket: étape 8, image 2 de 3 How to Repair a Leather Jacket Pocket: étape 8, image 3 de 3
    • To finish the stitch, tie a knot by crossing the remaining thread on top of each other to make an X shape.
    • Loop the top thread inside the hole and use your thumb to hold the thread in place.
    • Make sure your needle and thread are on the inside of your fabric, or else the final knot will be visible on the outside.
    Demander à FixBot
  9. How to Repair a Leather Jacket Pocket: étape 9, image 1 de 2 How to Repair a Leather Jacket Pocket: étape 9, image 2 de 2
    • Pull the needle to tighten the knot as close to the last stitch as you can. Repeat the knot 3 times in the same spot.
    Demander à FixBot
  10. How to Repair a Leather Jacket Pocket: étape 10, image 1 de 2 How to Repair a Leather Jacket Pocket: étape 10, image 2 de 2
    • Trim the remaining thread with scissors.
    • Tuck any remaining visible thread inside the fabric.
    • You may also use a needle to tuck in the remaining visible thread.
    Demander à FixBot
  11. How to Repair a Leather Jacket Pocket: étape 11, image 1 de 2 How to Repair a Leather Jacket Pocket: étape 11, image 2 de 2
    • Wear your newly-repaired leather jacket!
    Demander à FixBot
Ligne d'arrivée
Caitlyn
Membre depuis le 02/19/25
193 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 1-8, Andersen Winter 2025 Membre de l'équipe UC Davis, Team 1-8, Andersen Winter 2025
UCD-ANDERSEN-W25S1G8
3 membres
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 44
Total : 445
