Aller au contenu principal
How to Repair a Patio Solar Light
Ce dont vous avez besoin
  1. How to Repair a Patio Solar Light, How to Repair a Patio Solar Light: étape 1, image 1 de 1
    • Disassemble the circuit box using a Phillips screwdriver.
  2. How to Repair a Patio Solar Light: étape 2, image 1 de 1
    • Using a multimeter, put the black wire in the COM port, and the red wire into the far right port. Set the switch to 20 volts DC.
  3. How to Repair a Patio Solar Light: étape 3, image 1 de 1
    • Remove battery from the port.
    • Check both ends of the battery with the multimeter.
    • The red prong touches the negative side, and the black prong touches the positive side of the battery.
  4. How to Repair a Patio Solar Light: étape 4, image 1 de 1
    • Ensure that the multimeter screen shows a number that matches or is greater than the voltage of the battery. If not, replace the battery.
    • Check the circuit board for detached, or loosely connected wires.
  5. How to Repair a Patio Solar Light: étape 5, image 1 de 3 How to Repair a Patio Solar Light: étape 5, image 2 de 3 How to Repair a Patio Solar Light: étape 5, image 3 de 3
    • Use a soldering iron at 400 Celsius to melt your soldering wire. Gather a droplet on the tip of the soldering iron, and use the drop to reattach the disconnected wire back onto the circuit board.
    • CAUTION: Don't handle metal parts of the soldering iron without proper gloves and protection.
  6. How to Repair a Patio Solar Light: étape 6, image 1 de 1
    • Turn your solar light back on before reassembling to test if it’s working properly.
    • When the light turns on, reassemble your solar light.
Miguel Antonio Gonzales
Membre depuis le 02/20/24
133 Réputation
1 tutoriel rédigé
Équipe
University of Arizona, Team 2-7, Cools Stephens Spring 2024 Membre de l'équipe University of Arizona, Team 2-7, Cools Stephens Spring 2024
ARIZONA-COOLS STEPHENS-S24S2G7
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 198
