Aller au contenu principal
How to Repair a Portable Fan
Ce dont vous avez besoin
  1. How to Repair a Portable Fan, How to Repair a Portable Fan: étape 1, image 1 de 2 How to Repair a Portable Fan, How to Repair a Portable Fan: étape 1, image 2 de 2
    • Unplug the power cord before beginning.
    • Loosen the 4 phillips screws around the rim and remove the front of the cage
  2. How to Repair a Portable Fan: étape 2, image 1 de 1
    • Remove the fan blade by loosening the screw on the shaft while pulling up.
    • The screw does not need to be fully removed before the blade will slide free.
  3. How to Repair a Portable Fan: étape 3, image 1 de 1
    • Remove the wiring cover located above the fan motor.
    • There are 2 more screws holding the back mounting plate and cage together. They will be removed in a later step
  4. How to Repair a Portable Fan: étape 4, image 1 de 1
    • Remove the motor from the mounting plate by loosing the 2 smaller screws on the front.
  5. How to Repair a Portable Fan: étape 5, image 1 de 1
    • Remove the final 2 screws holding the mounting plate to the cage.
  6. How to Repair a Portable Fan: étape 6, image 1 de 1
    • Carefully pass the motor through the opening at the back of the cage.
  7. How to Repair a Portable Fan: étape 7, image 1 de 2 How to Repair a Portable Fan: étape 7, image 2 de 2
    • Using an 8mm wrench and phillips screwdriver, remove the magnet mounts from the body of the motor.
    • The magnet will slide out of the motor . Inspect the magnet and motor for anything that may cause a hang-up.
    • Do not over-tighten the magnet mounts during reassembly. Over-tightening may cause the motor to bind.
  8. How to Repair a Portable Fan: étape 8, image 1 de 2 How to Repair a Portable Fan: étape 8, image 2 de 2
    • Clean and lubricate the magnet shaft and mounting brackets
    • Any medium or low viscosity lubricant will do.
To reassemble your device, follow these steps in reverse order.
5 autres ont terminé cette réparation.
Isaac MacMillan
Membre depuis le 10/02/17
206 Réputation
1 tutoriel rédigé
Équipe
Michigan Tech, Team S5-G11, Galliah Fall 2017 Membre de l'équipe Michigan Tech, Team S5-G11, Galliah Fall 2017
MTU-GALLIAH-F17S5G11
2 membres
2 tutoriels rédigés
4 commentaires
What are the chances the exact fan that I need to repair would be here? I'm about to put it back together… Let's see if it worked! 9/3/19, 10:45 pm.
Clark Nova - Réponse
OK. It's back together but the fan doesn't spin. I feel the motor doing… Something. It vibrates softly. So, now to figure out why it's not spinning.
hello…my fan wouldn't work until I tilt the head upwards..what could be wrong pls???
adewale ogunbona - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 16
30 derniers jours : 70
Total : 19,934
