Aller au contenu principal
How to Repair a Resin Charm
Ce dont vous avez besoin
  1. How to Repair a Resin Charm, How to Repair a Resin Charm: étape 1, image 1 de 2 How to Repair a Resin Charm, How to Repair a Resin Charm: étape 1, image 2 de 2
    • Fit the broken pieces together with the flattest side of the charm facing towards you.
  2. How to Repair a Resin Charm: étape 2, image 1 de 2 How to Repair a Resin Charm: étape 2, image 2 de 2
    • Lay a piece of tape on the crack and press down smoothly.
  3. How to Repair a Resin Charm: étape 3, image 1 de 1
    • Pick up the pieces so the crack is facing up.
    • Bend the pieces to create a slight gap.
    • CAUTION: Wear gloves when working with resin.
  4. How to Repair a Resin Charm: étape 4, image 1 de 2 How to Repair a Resin Charm: étape 4, image 2 de 2
    • Add resin to the crack.
    • Press the pieces together.
  5. How to Repair a Resin Charm: étape 5, image 1 de 2 How to Repair a Resin Charm: étape 5, image 2 de 2
    • Use a cotton swab to spread the resin in the crack.
    • Pick up the excess resin with a cotton swab.
  6. How to Repair a Resin Charm: étape 6, image 1 de 3 How to Repair a Resin Charm: étape 6, image 2 de 3 How to Repair a Resin Charm: étape 6, image 3 de 3
    • Turn on the UV light.
    • Put the charm under the UV light for 120 seconds per side.
    • Remove the charm.
Now your charm is repaired and can once again be worn or displayed!
Jorja
Membre depuis le 04/25/24
133 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 2-7, Whithaus Spring 2024 Membre de l'équipe UC Davis, Team 2-7, Whithaus Spring 2024
UCD-WHITHAUS-S24S2G7
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 21
Total : 42
