Introduction
If your Squareplug SP400 patch cable isn’t producing clear audio, use this guide to resolder the broken connections.
Patch cables, even well-soldered ones, are susceptible to stress-breaks at their connections. This is usually caused by repeated plugging/unplugging with regular use. A simple resolder with fresh wire ends and solder balls should bring the cable back to life.
Before using this guide, double-check that it’s your patch cable that is faulty. It’s possible the source of the signal loss is elsewhere in the signal chain.
Ce dont vous avez besoin
Verify that the cable is faulty (unresponsive yellow and green LED indicators).
Yellow LED indicator
Green LED indicator
Desolder the existing solder connections.
Wick the existing solder completely off of the plug connections.
For more information on soldering, check out the How to Solder and Desolder Connections guide.
