Introduction
This guide will show you how to fix a stuck toilet handle. The handle of your toilet is responsible to start a chain reaction between parts of the toilet in order for it to flush. It is possible and common for one of these parts to malfunction, thus causing your toilet handle to feel stuck or unable to flush entirely. In most cases it is relatively simple to repair the stuck handle of a toilet by yourself, no plumbing experience necessary. This guide will show you how to un-stick your tank-mounted toilet’s handle in three different spots.
Ce dont vous avez besoin
Find the shut off valve behind the toilet.
To close the shut off valve, most toilet valves need to be turned to the left.
To reassemble your toilet, turn the water valve back on and put the lid back on.
