Aller au contenu principal
How to Repair an Unstable Sliding Door
Ce dont vous avez besoin
  1. How to Repair an Unstable Sliding Door, How to Repair an Unstable Sliding Door: étape 1, image 1 de 3 How to Repair an Unstable Sliding Door, How to Repair an Unstable Sliding Door: étape 1, image 2 de 3 How to Repair an Unstable Sliding Door, How to Repair an Unstable Sliding Door: étape 1, image 3 de 3
    • Investigate the cause of the unstable sliding door.
    • In this case you can see the sliding tract isn't aligned with the bottom roller.
    • You can also see that the screw at the base has been dislodged.
  2. How to Repair an Unstable Sliding Door: étape 2, image 1 de 3 How to Repair an Unstable Sliding Door: étape 2, image 2 de 3 How to Repair an Unstable Sliding Door: étape 2, image 3 de 3
    • Remove the screws used to hold the door in place with a Phillips screwdriver.
    • Once the doors are loose from the tracks, remove them.
  3. How to Repair an Unstable Sliding Door: étape 3, image 1 de 3 How to Repair an Unstable Sliding Door: étape 3, image 2 de 3 How to Repair an Unstable Sliding Door: étape 3, image 3 de 3
    • Check to see that the rollers are securely in place.
    • If there are any bits of debris present on the rollers or the tracks, clean it off with isopropyl alcohol and a clean rag.
  4. How to Repair an Unstable Sliding Door: étape 4, image 1 de 3 How to Repair an Unstable Sliding Door: étape 4, image 2 de 3 How to Repair an Unstable Sliding Door: étape 4, image 3 de 3
    • Place the doors back on the rollers.
    • Replace the screws you removed earlier.
    • Check that the rollers move freely. You can test this by using your hands to roll them forward to your satisfaction.
  5. How to Repair an Unstable Sliding Door: étape 5, image 1 de 3 How to Repair an Unstable Sliding Door: étape 5, image 2 de 3 How to Repair an Unstable Sliding Door: étape 5, image 3 de 3
    • Align the door on both tracks.
    • Start by attaching the head of the door first and then lower body into the track. Avoid forcing into the track as this might damage the rollers.
    • Make sure that it is aligned properly so it does not fall out in the future.
Ligne d'arrivée
Barabonye Longjohn
Membre depuis le 09/21/20
121 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G30, Woodhouse Fall 2020 Membre de l'équipe York University, Team S1-G30, Woodhouse Fall 2020
YORK-WOODHOUSE-F20S1G30
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 7
Total : 321
