Aller au contenu principal
How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.
Ce dont vous avez besoin
  1. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower., How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: étape 1, image 1 de 1
    • Start with a flat, open space to work.
  2. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: étape 2, image 1 de 2 How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: étape 2, image 2 de 2
    • Unscrew these three 1.2 mm screws.
  3. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: étape 3, image 1 de 1
    • Remove the Bubble Sprocket from the motor.
  4. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: étape 4, image 1 de 1
    • Unscrew these four 1.2mm screws holding the plate on.
  5. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: étape 5, image 1 de 1
    • Remove the plate.
  6. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: étape 6, image 1 de 1
    • Connect the red wire to the top right pin.
  7. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: étape 7, image 1 de 1
    • Solder the Red wire to the metal pin.
    • (Warning Soldering is very hot!)
  8. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: étape 8, image 1 de 2 How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: étape 8, image 2 de 2
    • Connect the yellow wire to the bottom right pin.
    • Solder the yellow wire to the bottom right pin.
    • (Warning Soldering iron is very hot!)
  9. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: étape 9, image 1 de 1
    • Replace the plate over the wires.
  10. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: étape 10, image 1 de 1
    • Put four 1.2 mm screws for the plate back into place.
  11. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: étape 11, image 1 de 1
    • Put three 1.2mm screws for the motor back into place.
  12. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: étape 12, image 1 de 1
    • Insert the Bubble sprocket onto the motor.
  13. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: étape 13, image 1 de 1
    • You are now finished!
Ligne d'arrivée
John Hiller
Membre depuis le 10/05/15
110 Réputation
1 tutoriel rédigé
Équipe
Colorado Springs, Team 7-5, Mcmichael Fall 2015 Membre de l'équipe Colorado Springs, Team 7-5, Mcmichael Fall 2015
UCCS-MCMICHAEL-F15S7G5
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 24
Total : 1,820
