Aller au contenu principal
How to Replace 2005 Toyota Camry Cabin Air Filter
Ce dont vous avez besoin
  1. How to Replace 2005 Toyota Camry Cabin Air Filter, Cabin Air Filter: étape 1, image 1 de 3 How to Replace 2005 Toyota Camry Cabin Air Filter, Cabin Air Filter: étape 1, image 2 de 3 How to Replace 2005 Toyota Camry Cabin Air Filter, Cabin Air Filter: étape 1, image 3 de 3
    • Turn off the car.
    • Remove the key from the ignition.
  2. How to Replace 2005 Toyota Camry Cabin Air Filter: étape 2, image 1 de 3 How to Replace 2005 Toyota Camry Cabin Air Filter: étape 2, image 2 de 3 How to Replace 2005 Toyota Camry Cabin Air Filter: étape 2, image 3 de 3
    • Open the passenger side door.
  3. How to Replace 2005 Toyota Camry Cabin Air Filter: étape 3, image 1 de 2 How to Replace 2005 Toyota Camry Cabin Air Filter: étape 3, image 2 de 2
    • Open the glove box in the passenger seat of your car, and empty anything inside.
  4. How to Replace 2005 Toyota Camry Cabin Air Filter: étape 4, image 1 de 1
    • Use a Phillips #2 screwdriver to remove the single 16.2 mm screw retaining the rod hook on the right side of the glove box.
  5. How to Replace 2005 Toyota Camry Cabin Air Filter: étape 5, image 1 de 2 How to Replace 2005 Toyota Camry Cabin Air Filter: étape 5, image 2 de 2
    • Detach the rod hook from the hinge.
  6. How to Replace 2005 Toyota Camry Cabin Air Filter: étape 6, image 1 de 2 How to Replace 2005 Toyota Camry Cabin Air Filter: étape 6, image 2 de 2
    • Press inward on both sides of the glove box to release the stops.
    • Remove the glove box and set it aside.
  7. How to Replace 2005 Toyota Camry Cabin Air Filter: étape 7, image 1 de 2 How to Replace 2005 Toyota Camry Cabin Air Filter: étape 7, image 2 de 2
    • Push inward on each side of the air filter to unclip it.
  8. How to Replace 2005 Toyota Camry Cabin Air Filter: étape 8, image 1 de 2 How to Replace 2005 Toyota Camry Cabin Air Filter: étape 8, image 2 de 2
    • Slide the cabin air filter directly out of its compartment.
  9. How to Replace 2005 Toyota Camry Cabin Air Filter: étape 9, image 1 de 3 How to Replace 2005 Toyota Camry Cabin Air Filter: étape 9, image 2 de 3 How to Replace 2005 Toyota Camry Cabin Air Filter: étape 9, image 3 de 3
    • Push on the bottom of the air filter to loosen it from the plastic frame.
    • Flip the filter over and push the side of it until it releases from the frame.
  10. How to Replace 2005 Toyota Camry Cabin Air Filter: étape 10, image 1 de 1
    • Install the new filter by pressing it into the plastic frame.
  11. How to Replace 2005 Toyota Camry Cabin Air Filter: étape 11, image 1 de 1
    • Slide the folds of the new filter towards one end of the frame so that the entire filter fits within the plastic tightly.
  12. How to Replace 2005 Toyota Camry Cabin Air Filter: étape 12, image 1 de 2 How to Replace 2005 Toyota Camry Cabin Air Filter: étape 12, image 2 de 2
    • Slide the air filter into its compartment until it clicks into place.
  13. How to Replace 2005 Toyota Camry Cabin Air Filter: étape 13, image 1 de 3 How to Replace 2005 Toyota Camry Cabin Air Filter: étape 13, image 2 de 3 How to Replace 2005 Toyota Camry Cabin Air Filter: étape 13, image 3 de 3
    • Push inward on both sides of the glove box.
    • Raise the glove box until it holds in the housing without support.
  14. How to Replace 2005 Toyota Camry Cabin Air Filter: étape 14, image 1 de 2 How to Replace 2005 Toyota Camry Cabin Air Filter: étape 14, image 2 de 2
    • Pull down the rod on the right side of the glovebox and push the hook back around the hinge.
  15. How to Replace 2005 Toyota Camry Cabin Air Filter: étape 15, image 1 de 1
    • Screw in the 16.2 mm Philips #2 screw that holds the damper rod in place.
  16. How to Replace 2005 Toyota Camry Cabin Air Filter: étape 16, image 1 de 2 How to Replace 2005 Toyota Camry Cabin Air Filter: étape 16, image 2 de 2
    • Replace your items and close the glove box.
Enjoy the fresh air!
2 autres ont terminé cette réparation.
Saorla Miller
Membre depuis le 02/26/22
301 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 32
30 derniers jours : 129
Total : 2,561
