Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Replace HID Headlight Bulbs
  1. How to Replace HID Headlight Bulbs, HID Headlight Bulb: étape 1, image 1 de 2 How to Replace HID Headlight Bulbs, HID Headlight Bulb: étape 1, image 2 de 2
    • Open the hood and then locate the back of the headlights.
    Demander à FixBot
    Ajouter un commentaire
  2. How to Replace HID Headlight Bulbs: étape 2, image 1 de 1
    • Remove the cap covers behind the headlights.
    Demander à FixBot
  3. How to Replace HID Headlight Bulbs: étape 3, image 1 de 2 How to Replace HID Headlight Bulbs: étape 3, image 2 de 2
    • Once you can see the OEM headlight bulb, twist and unlock to take it out.
    Demander à FixBot
  4. How to Replace HID Headlight Bulbs: étape 4, image 1 de 2 How to Replace HID Headlight Bulbs: étape 4, image 2 de 2
    • For a lot of D1S and D3S, there's a bulb retainer, which you will need to remove.
    Demander à FixBot
  5. How to Replace HID Headlight Bulbs: étape 5, image 1 de 1
    • Examine your stock bulb. Make sure that the labeling on the OEM bulb is the same as the new HID bulb.
    • For example, this particular vehicle uses D1S stock bulb. You'll need to make sure that the HID replacement bulb is also labeled as D1S.
    • D1S and D3S are not interchangeable, so if you find that the labeling does not match, you will need to exchange for the correct size.
    Demander à FixBot
  6. How to Replace HID Headlight Bulbs: étape 6, image 1 de 3 How to Replace HID Headlight Bulbs: étape 6, image 2 de 3 How to Replace HID Headlight Bulbs: étape 6, image 3 de 3
    • Take a look at the pins inside of the bulb. You can see that there is 1 pin by itself, a gap, and then 2 pins together. When you connect the new HID headlight bulb to the adapter, the pin direction needs to match! Look closely at the adapter and you will see numbers denoting slots 1,2, and 4.
    • Make sure that the pins on the HID headlight bulb and the pin slots on the adapter directly match prior to connection. If you connect the HID headlight bulb and the adapter the wrong way, the connection will still go in, but the incorrect insert WILL cause the bulb to have issues such as not lighting up, flickering, or damage to your vehicle.
    • So before connecting the HID headlight bulb to the adapter, make sure that the pins from the HID headlight bulb match the corresponding open slots on the adapter.
    Demander à FixBot
  7. How to Replace HID Headlight Bulbs: étape 7, image 1 de 2 How to Replace HID Headlight Bulbs: étape 7, image 2 de 2
    • Now you can install the HID headlight bulb back with the original retainer and then insert it back the same way you removed the OEM bulb.
    Demander à FixBot
  8. How to Replace HID Headlight Bulbs: étape 8, image 1 de 2 How to Replace HID Headlight Bulbs: étape 8, image 2 de 2
    • Put all the components back in place and enjoy your new HID headlights.
    Demander à FixBot
As you can see, it's very straight forward to install. Installing this HID Replacement Bulb will give you light when yours burnt out.
7 autres ont terminé cette réparation.
Eric Wu
Membre depuis le 01/21/15
3 600 Réputation
23 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 14
7 derniers jours : 79
30 derniers jours : 374
Total : 10,080
