Aller au contenu principal
How to Replace a Broken Blind Slat
Ce dont vous avez besoin
  1. How to Replace a Broken Blind Slat, Horizontal Blind Slat: étape 1, image 1 de 1
    • Using the 7/32" flathead screwdriver, gently lift up the buttons located on the bottom rail of the blinds.
    • Make sure to be careful when lifting the bottom buttons to avoid injury and button damage.
  2. How to Replace a Broken Blind Slat: étape 2, image 1 de 2 How to Replace a Broken Blind Slat: étape 2, image 2 de 2
    • Remove the bottom rail buttons to expose knots at the end of the lifting cords.
    • Untie the knots.
  3. How to Replace a Broken Blind Slat: étape 3, image 1 de 1
    • Start at the highest damaged slat.
    • Begin pulling the lifting cords up through the route holes of all the following blind slats.
    • If you don't start from the highest slat, it will result in you doing way more work than you have to.
  4. How to Replace a Broken Blind Slat: étape 4, image 1 de 2 How to Replace a Broken Blind Slat: étape 4, image 2 de 2
    • Again, start with the highest slat.
    • Begin removing the broken slat(s) from in between the ladder strings.
  5. How to Replace a Broken Blind Slat: étape 5, image 1 de 1
    • Slide in the replacement slat(s).
    • Be sure the slat(s) sits in place upon the rungs of the ladder strings.
  6. How to Replace a Broken Blind Slat: étape 6, image 1 de 1
    • With the new replacement slats in place, begin at the highest slat.
    • Create a loop with the lifting cords.
    • Slide the loop through each routing hole on the same side of all the slats.
    • Repeat this step on the other side, and in the middle if your blinds have three routing holes.
  7. How to Replace a Broken Blind Slat: étape 7, image 1 de 3 How to Replace a Broken Blind Slat: étape 7, image 2 de 3 How to Replace a Broken Blind Slat: étape 7, image 3 de 3
    • Once you reach the bottom slat, thread the lifting cords back through the bottom rail.
    • Make sure the lifting cords are even in length and the bottom rail is aligned straight horizontally.
  8. How to Replace a Broken Blind Slat: étape 8, image 1 de 3 How to Replace a Broken Blind Slat: étape 8, image 2 de 3 How to Replace a Broken Blind Slat: étape 8, image 3 de 3
    • Use the 7/32" flathead screwdriver to push the excess lifting cords into the bottom rail holes.
    • Slide the buttons back over the ends of the cords.
    • At each bottom rail button, double knot the lifting cords.
  9. How to Replace a Broken Blind Slat: étape 9, image 1 de 1
    • Plug the buttons back into the bottom rail.
  10. How to Replace a Broken Blind Slat: étape 10, image 1 de 2 How to Replace a Broken Blind Slat: étape 10, image 2 de 2
    • Lastly, gently hammer the bottom rail buttons with the handle of the 7/32" flathead screwdriver to ensure the button is securely fastened.
3 autres ont terminé cette réparation.
Jazmine Atkins
Membre depuis le 01/25/20
265 Réputation
1 tutoriel rédigé
Équipe
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 Membre de l'équipe USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020
USFSM-STEWART-S20S1G1
23 membres
30 tutoriels rédigés
2 commentaires
Very good tutorial. Thank you.
LaReisa Cares - Réponse
What happened when that string retracts and goes missing ?
Mary Nguyen - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 81
30 derniers jours : 274
Total : 17,466
