Aller au contenu principal
How to Replace a Broken Lanyard Clasp
Ce dont vous avez besoin
  1. How to Replace a Broken Lanyard Clasp, Clasp: étape 1, image 1 de 3 How to Replace a Broken Lanyard Clasp, Clasp: étape 1, image 2 de 3 How to Replace a Broken Lanyard Clasp, Clasp: étape 1, image 3 de 3
    • Use a seam ripper to carefully rip the seam holding the existing clasp.
  2. How to Replace a Broken Lanyard Clasp: étape 2, image 1 de 3 How to Replace a Broken Lanyard Clasp: étape 2, image 2 de 3 How to Replace a Broken Lanyard Clasp: étape 2, image 3 de 3
    • Remove the existing clasp from the lanyard.
    • Use thread nippers to remove any remaining strings or fraying edges from the lanyard.
    • Make sure to trim as close to the base of the lanyard as possible without cutting into the main material.
  3. How to Replace a Broken Lanyard Clasp: étape 3, image 1 de 3 How to Replace a Broken Lanyard Clasp: étape 3, image 2 de 3 How to Replace a Broken Lanyard Clasp: étape 3, image 3 de 3
    • Using a tape measure, measure out 24 inches (2 ft) of your choice of thread.
    • Snip the thread at the correct length with thread nippers.
    • Use as much thread as you think is necessary, keep in mind that a larger amount of thread can be tangled more easily.
  4. How to Replace a Broken Lanyard Clasp: étape 4, image 1 de 2 How to Replace a Broken Lanyard Clasp: étape 4, image 2 de 2
    • Feed one end of the cut thread through the eye of the needle.
    • Sometimes licking the end of the thread can make it easier to thread through the needle.
  5. How to Replace a Broken Lanyard Clasp: étape 5, image 1 de 1
    • Pull the thread through the needle until the needle sits directly in the middle of the thread.
  6. How to Replace a Broken Lanyard Clasp: étape 6, image 1 de 3 How to Replace a Broken Lanyard Clasp: étape 6, image 2 de 3 How to Replace a Broken Lanyard Clasp: étape 6, image 3 de 3
    • With the lower part of the thread, cross both sides over each other.
    • Tie the two sides together, making sure the knot stays towards the bottom of the thread.
  7. How to Replace a Broken Lanyard Clasp: étape 7, image 1 de 3 How to Replace a Broken Lanyard Clasp: étape 7, image 2 de 3 How to Replace a Broken Lanyard Clasp: étape 7, image 3 de 3
    • Line up both sides of the lanyard.
    • Place the joined ends through the bottom of the new clasp.
    • Fold the lanyard over the bottom of the clasp.
    • Different lanyards may be configured differently. Follow the previous fold lines on your lanyard to best note how to rejoin the ends.
  8. How to Replace a Broken Lanyard Clasp: étape 8, image 1 de 2 How to Replace a Broken Lanyard Clasp: étape 8, image 2 de 2
    • Take the threaded needle and poke it through on one side of the lanyard.
    • Pull the needle and thread all the way through until the knot catches on the underside of the lanyard.
    • Make sure your needle goes through all the layers of the lanyard, paying particular attention to include the folded part.
  9. How to Replace a Broken Lanyard Clasp: étape 9, image 1 de 3 How to Replace a Broken Lanyard Clasp: étape 9, image 2 de 3 How to Replace a Broken Lanyard Clasp: étape 9, image 3 de 3
    • Push the needle back down through all layers of the lanyard.
    • Pull all the way through until the thread is tight.
    • Continue moving back and forth across the lanyard until you reach the other end.
    • Keep the stitches as close together as possible for better stability.
  10. How to Replace a Broken Lanyard Clasp: étape 10, image 1 de 1
    • Leave enough thread to comfortably tie a knot, so avoid cutting it too close to the lanyard.
    • Clip the thread in the middle of the remaining length.
    • Make sure you place your needle in a safe place now that is it free from the thread.
  11. How to Replace a Broken Lanyard Clasp: étape 11, image 1 de 3 How to Replace a Broken Lanyard Clasp: étape 11, image 2 de 3 How to Replace a Broken Lanyard Clasp: étape 11, image 3 de 3
    • Cross the edges of the thread still attached to the lanyard.
    • Tie them together, making sure to tighten them down to the lanyard.
    • Repeat this a couple more times to ensure it won't come undone.
  12. How to Replace a Broken Lanyard Clasp: étape 12, image 1 de 1
    • Clip the remaining thread.
    • The stitching should be secure so cut closely to the knot on the end.
  13. How to Replace a Broken Lanyard Clasp: étape 13, image 1 de 1
    • All done! Enjoy your new lanyard clasp.
Ligne d'arrivée
Keely Hunt
Membre depuis le 01/30/24
238 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 2-6, Andersen Winter 2024 Membre de l'équipe UC Davis, Team 2-6, Andersen Winter 2024
UCD-ANDERSEN-W24S2G6
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 18
30 derniers jours : 87
Total : 195
