Introduction
As wand tilt mechanisms age, they can crack and break internally. Instead of replacing the entire window shade or blind, the process of just replacing the broken wand tilt mechanism inside the window blind is quite simple!
The price of a new window blind typically ranges from $80-$400. Whereas, just replacing the tilt wand mechanism is $10. Not only are you saving money, but you will greatly decrease the amount of waste going to the landfill.
Lift up the wand sleeve with your fingers to clear access for the wand to slide out.
Once the sleeve is pushed up, rotate the wand horizontally to unhook it from the tilt mechanism.
2 autres ont terminé cette réparation.
