Aller au contenu principal
How to Replace a Croc Ankle Strap Rivet
Ce dont vous avez besoin
  1. How to Replace a Croc Ankle Strap Rivet, Croc Rivet: étape 1, image 1 de 3 How to Replace a Croc Ankle Strap Rivet, Croc Rivet: étape 1, image 2 de 3 How to Replace a Croc Ankle Strap Rivet, Croc Rivet: étape 1, image 3 de 3
    • Use a flathead screwdriver to pry underneath the plastic rivet head.
    • Wiggle the plastic rivet until the head pops off.
  2. How to Replace a Croc Ankle Strap Rivet: étape 2, image 1 de 3 How to Replace a Croc Ankle Strap Rivet: étape 2, image 2 de 3 How to Replace a Croc Ankle Strap Rivet: étape 2, image 3 de 3
    • Use your hands to remove the remaining part of the old rivet from inside the Croc.
  3. How to Replace a Croc Ankle Strap Rivet: étape 3, image 1 de 3 How to Replace a Croc Ankle Strap Rivet: étape 3, image 2 de 3 How to Replace a Croc Ankle Strap Rivet: étape 3, image 3 de 3
    • Flip the Croc strap to the front of the sandal and apply a binder clip to hold the strap in place.
  4. How to Replace a Croc Ankle Strap Rivet: étape 4, image 1 de 3 How to Replace a Croc Ankle Strap Rivet: étape 4, image 2 de 3 How to Replace a Croc Ankle Strap Rivet: étape 4, image 3 de 3
    • Insert the end of the new rivet through the hole from the inside of the Croc.
  5. How to Replace a Croc Ankle Strap Rivet: étape 5, image 1 de 3 How to Replace a Croc Ankle Strap Rivet: étape 5, image 2 de 3 How to Replace a Croc Ankle Strap Rivet: étape 5, image 3 de 3
    • Place the head of the new rivet through the hole of the Croc strap.
    • Move the Croc strap so that the rivet head aligns with the opening of the rivet tail.
  6. How to Replace a Croc Ankle Strap Rivet: étape 6, image 1 de 2 How to Replace a Croc Ankle Strap Rivet: étape 6, image 2 de 2
    • Use a flathead screwdriver to turn the rivet head clockwise to tighten it.
  7. How to Replace a Croc Ankle Strap Rivet: étape 7, image 1 de 3 How to Replace a Croc Ankle Strap Rivet: étape 7, image 2 de 3 How to Replace a Croc Ankle Strap Rivet: étape 7, image 3 de 3
    • Remove the binder clip.
  8. How to Replace a Croc Ankle Strap Rivet: étape 8, image 1 de 3 How to Replace a Croc Ankle Strap Rivet: étape 8, image 2 de 3 How to Replace a Croc Ankle Strap Rivet: étape 8, image 3 de 3
    • To test for tightness, move the strap towards the back of the sandal.
    • If the strap bends instead of rotating freely, the screw is on too tight.
    • If necessary, to loosen the Croc strap, rotate the rivet head counterclockwise using a flathead screwdriver.
  9. How to Replace a Croc Ankle Strap Rivet: étape 9, image 1 de 3 How to Replace a Croc Ankle Strap Rivet: étape 9, image 2 de 3 How to Replace a Croc Ankle Strap Rivet: étape 9, image 3 de 3
    • Check that the Croc strap can rotate freely.
Andy
Membre depuis le 04/19/23
169 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 2-1, Morris Spring 2023 Membre de l'équipe UC Davis, Team 2-1, Morris Spring 2023
UCD-MORRIS-S23S2G1
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 27
7 derniers jours : 206
30 derniers jours : 686
Total : 6,176
